Xiaomi Mi Max
imjoseph
Fantastic phone with reasonable pricing and good specs and long battery life. Camera not too bad after some minor edits of pic in instagram. Loving it so much that I'm thinking to get another one just incase the current one dies.
dont put poison lei... tao yan...
kandinsky
i'm still trying my utmost to figure out how to squeeze my nano sim card into the slot 1 along with a micro sd card.
Is there some trick to this? Or should I just stick the nano sim into a sim card adapter and put it into slot 2? :s22:
Oinkize
If you are using the 4g+3g features , how do you set SIM 2 on data ?
In the Setting -> SIM cards & mobile networks-> Mobile data (this is switch-on) and further below is "Internet" pointed to SIM 1.
So to use SIM 2 data , is it change the "Internet" to SIM 2?
Yes. That is correct.
touchme
melt and stick SIM to card, mentioned few times here. Lookup YouTube.
kelvinti
Ya!
Never regretted U Turn back to Mi Max after selling my 1st one.
Really damn shiok for playing games. Everything is big and that makes it easy to hit the target and win. :)
Those who are still standing at the edge of UOB Tower, please jump now to get the Mi Max.
Poison? I would say this is a good antibiotic. :)
SongManKranji
High Honorary Member
Ya!
bro I like the way u describe ha ha damn song ah
Sent from Samsung GT-N7105 using GAGT
SPEED
anyone got which glass protector to recommend
i get from qoo10 and taobao
all cannot stick well
the 4 sides all got rainbow.
cannot stick to the mi max screen due to the mi max curved screen at the sides
best_ctzn
Open Security app, change the following options :
- Permission, autostart Whatsapps
- Battery, App Battery, choose Whatsapps set to no restriction, then switch off Battery Saver
Do the same for Telegram
Reboot...
Done
The lag really reduce by quite abit after I did the full changes recommended above. Thanks.
jace88
I am too chicken to do this lol
On another note I ended up ordering a local set from hachi tech ie Challenger. I figured I had rebate and online credit card rebate so works out to be around 320ish I think.
kelvinti
Aliexpress.
Choose either White or gold or silver front bezel. :)
I'm using it. Full coverage. No rainbow, no white spot, no problem with my case.
Original Mocolo Brand 3D Full Cover Premium Tempered Glass Screen Protector For Xiaomi Max 6.44" for mi max glass film
http://s.aliexpress.com/ZRzUFRrY
(from AliExpress Android)
charleslee
Aliexpress.
I'm looking for Rose Gold coloured ones, but Mocolo brand dun seem to have them :(
