kelvinti
- Jan 5, 2009
Normally how long are the intervals between phone batches for beta updates?
Within 24 hours, everyone should get it in Singapore.
GF dropped her phone from around 1.2m height straight onto the hard floor... Screen Protector cracked, casing have scratches. But nothing happened to the phone! Lucky lucky!!
But now need to wait 2weeks for new screen protector...
Sent from MiMax using GAGT
I got the gold one, no dots and no rainbow.
Basket, I so suay buy white![]()
for me haha. I bought two white both also have. But seriously, still quite usable, both effect are quite minimal in actual usage.
The grid white dots are not issue at all lah.
Do let us know if it's China Set/India Set; Global or China software rom....
Thanks in advance.. =)
Btw.. mind to ask.... is the tempered glass screen protector and the casing with finger ring attached... available locally?
Wah ... from 1.2m is quite high. Which casing is the Mi Max on? As for the screen protector, it is so cheap that just buy one for standby.
Now I am thinking whether should I buy gold one or black. Black colour will make the whole front part looks like screen, which will appear huge!
Why did you opted for the white one? I mean the black one at least still make sense.
Guys be careful with your volume rockers. They are very soft.. I left a pen together with my mi max in my pocket today, somehow the pen pressed onto the volume rockers and bent it inwards.
The rocker got stuck and I couldn't press volume up or down. I had to tear apart the backing to bend the rockers back to shape.
It's working fine now. Good that the back is pretty easy to rip out..
Hi,
Anyone have problem with calls? The volume is always high, and cant be controlled using the volume rockers. When controlled in the settings the media volume, it will be re-adjusted back to the original loud volume, without changing the slider, seemingly like a auto-volume or something like that.
But hor... The black one doesn't match well or blend in well with the side silver or golden bezel as there is still tiny gap. Kekeke.
Go for the gold lah. Kekeke.
While waiting for the screen protector to arrive...u better get a cheap screen protector locally before she drop again. LolGF dropped her phone from around 1.2m height straight onto the hard floor... Screen Protector cracked, casing have scratches. But nothing happened to the phone! Lucky lucky!!
