Xiaomi Mi Max
cscs3
I am told there are 2 versions (India and China). India comes with pre installed playstore. Anyone can share what are the other differences? Wanted to get a set for my mum but better to have pre-installed playstore
Hardware is the same. Just one is China rom (no playstore). The other is global rom.
bockers
India sets are made in India and China sets are made in China.
India sets come with a 2 round pin charger and China sets come with a 2 flat pin charger.
India sets also have extra printing on the back at the bottom under the Mi logo. I find this ugly so I'd prefer to get a China set and then flash to Global rom myself.
jace88
Any help to Pokemon go lag issue ? Thanks
Mine got too. Sometimes I need to reenable GPS using GPS (rather than wifi) and then even when working, trying to catch Pokemon can be very laggy like the ball opens but doesn't actually catch and then the Pokemon does the animations as normal with an open poke ball in corner.
DRAGONGUY
im on 7314 but i still experience ads sometimes, maybe because i installed opera mini.
why go for eu ROM since you said 7314 ROM shows no problem?
Becoz previously i already flashed to china stable rom when i got the phone in june and i can't find any downloads for 7.3.14 despite searching up and down for it.
sellun
Mine is India set. The printing under mi logo is a sticker which can be removed.
Sent from MiMax using GAGT
roidred
Mine is v7.3.15.0 MBDCNDE. I saw a link to download this ROM in MIUI forum. Will try Eu ROM after some days will wait for your feedback how the EU ROM performs.
Nakedtoes
Lucky mine Indian set no ugly wordings behind..
DRAGONGUY
No worry, just change to this rom if you want to. It's a proven rom anyway. It's base on china miui 8 beta as of now and without those china apps. Very clean and debloated rom. Playstore is default.
Only thing i complain is the smartcover mode, it just get off whenever i reboot the devices. Other than that, snappy and clean.
legendary
Hi all, just wanted to clarify a doubt between China set and India set. I have recently purchased a 32gb set from Smart Cell Mobile. I assumed I gotten a China set as the words on the box is in Mandarin. Upon switching on the phone, the rom in my phone is Global Stable Rom and also able to receive MIUI 8 upgrade OTA. Even after a factory reset, it remained as Global Stable Rom.
I remember it was also mentioned earlier on by one of the member that all the 32gb sets purchased from Smart Cell Mobile will come with Global Stable Rom, be it China or India Set. Hope this clarify some doubts. Cheers...
Geo
I called Smartcell and they told me they'd flash the phone to official global rom if it is a China set. For India, they don't flash as it is already on global rom.
cscs3
Check with my friend. Also gotten from Smart Cell. All english words. However IMEI sticker on box and phone still print Made in China.
One clear different (from my China Redmi Note 2) is no sticker the scratch to verify true Xiaomi phone.
Anyway he is happy as no issue with Playstore. Unlike my China set with patched Playstore. It will get issue once a while till I finally gave up and flash to global rom.
legendary
Thanks for the clarification. So I think for those that are still worried that they might get a China Rom Set, can consider purchasing from Smart Cell Mobile. Do note this is only applicable for the 32gb set. Cheers...
Geo
Yes, pretty safe to purchase from Smartcell if u don't know how to flash. Too bad there's no official global rom for 64GB/128GB versions, else Smartcell would have brought them into SG.
