Xiaomi Mi Max
CrucifyMyLove
every phone has its pros & cons
it is not all abt the pros but it is whether u can accept the cons
LonelyMan
For those with quick charge 3.0 charger, how many % does it charge for 10 mins? I am assuming it charges from below 50%. Also, how long to charge from 0-100%?
Thanks in advance for sharing.
tjkjean
For those who feel that the icon and font etc are too big... can try this.
http://android.wonderhowto.com/how-...creen-resolution-without-root-access-0160439/
i changed my DPI from 440 to 380 (lowest without distortion to icon) and it looks so much better!
Better use of screen estate imo...
*Info
For step 2, if you are win user, change
adb shell dumpsys display | grep mBaseDisplayInfo
to
adb shell dumpsys display > [path]\display.txt
*[path] = location u want to store the text file
Then use notepad to open it if you want to see
DaRRenLieW
*Info
to
I use nove launcher since donkey year back and the icon look good in any device i used. True that miui os look abit like huawei. Kinda plain and turn off :/
joytezt
It's not the launcher issue. It's the size of everything. Eg. Seeing more rows of chats in Whatsapp, menu bar and everything will be smaller.
Yup, changed my dpi to 360, minor distortion is acceptable to me, and some apps think the Max is a tablet.
gerald27
Here are some information for Xiaomi MAX taken from my phone for your reference:
  • SD 650 Processor
  • NFC not supported
  • About 2 days of battery life (based on my own usage)
  • 8 hours of SOT
  • Getting about 1.7A from Sony Charger CP-AD2
gerald27
Any screenshots to share?
Curious to see how it looks like before i actually do it :s12:
qyc_91
  • SD 650 Processor
  • NFC not supported
  • 8 hours of SOT
8 HOURS SOT :eek:
LonelyMan
The current from the Ampere app is not very good, seems like it didn't reflect the voltage change which is what QC, Fast Charge and USB PD is about.
Audiology93
Did u try playing 1080p60 videos or even 1440p videos to see if it is smooth?
Thanks for sharing the above!!
No problem playing even 2160p vid on my RMNote 3 with the same SD650 processor. Mi Max can record 2160p video so confirm can play.
10:06 onwards
