raptorized
- Nov 26, 2011
Where do you guys get your tempered glass protectors? Some of the reviews I see on qoo10 are quite bad
Received mine yesterday. Sealed package.
Haven set up it yet but I have switched it on and I noticed that playstore is showing on my screen. Is it normal?
I thought china ROM will not have playstore?
The set is reseal by reseller after they break the original seal to install playstore.
If you observe carefully, you will notice the seal you have is different from original seal.
You can search on YouTube to see how ppl use hotair gun to do the seal.
i see! i think they helped me installed for free then lol... because i didnt pay the extra $5 for that installation service
Checked if the pre-installed MIUI ROM is the same as the MIUI ROM on http://en.miui.com/, some resellers preload a tampered MIUI ROMs which may take some confidential infos of yours.i see! i think they helped me installed for free then lol... because i didnt pay the extra $5 for that installation service
Sent from using GAGT
I don't know if this is normal for China ROM Xiaomi phones or not but ....
When there is an update available like Whatsapp, why does the phone always go Mi App Store to update itself instead of Google Playstore?
The reaction is the same when i try to download some new themes for my Amber Weather Widget. It goes into Mi App Store to locate the themes, and never to Google Playstore .... which means i can never download any new themes![]()
I feel your frustration coz I owned a China Redmi note 2 and I sold it off too. Sg local note 2 does not have this MI App Store install and work perfectly with Google play store. Maybe someone who is expert of rooting the phone can help on it.
nope, doesn't workMaybe you can try turn off everything from setting->system apps->app store.
You could have install the global rom on your Redmi note 2. Problem solved.
Just uninstall the MI App store if your primary application is with Google play store.
Remember China rom version is not suppose to have Google play store.
