Grandturismo
- Mar 1, 2007
FuLL coverage type!Mine is Gold front!
https://www.aliexpress.com/w/wholes...9&initiative_id=SB_20161004042842&needQuery=n
My order is on the way!
Wet table again!!!
I'm using Mi Max with MIUI 6.9 version (initially it was MIUI 8 Beta - pre-installed by a local store as it's a China version).
Since the last two updates (from 6.8 version of weekly update onwards), I'm facing a problem whereas in several occasion I can't unlock the phone despite having touch the fingerprint sensor several times and key-in the correct password several times. As the result I have to wait for several minutes before trying to key-in the password and eventually the phone accepted my password.
I'm just wondering whether any of you have the same experience and can advise to overcome this issue as it's hassle when you need to make a call or else.
KNN! You boi song my wet table again! Let's settle outside.. Haha.
I love wet wet very much. Lolllll.
Just received my mocolo screen protector from aliexpress. Surprised by the high quality packaging and the screen protector definitely the best in market for mimax. Confirm no rainbow effect.
Very worth it for few dollars.
Sent from MiMax using GAGT
come let's show our desktop.
me start first,
anyone?
me start first,
anyone?
Apologies - Sellun and Kelvinti.. just to ask...
Which shipping method did both of you use? How long it took to arrive?
Saw the link, prices vary among the stores.... dunno which to choose.... =(
Thanks in advance...
Just curious... jazzman80.....
No offense, what's that app over there? Bedroom T*****
Thanks...
Wat launcher is this
These are the steps to add fingerprint:
1. Go the Setting>Lock screen & password>Screen lock & fingerprint
2. It is prompt you to to confirm your pattern, do so to unlock
3. Screen will goes back to the Screen lock & fingerprint menu
4. Tap on Add fingerprint, and it will prompt you to confirm pattern again, do so to unlock the 2nd time and you will come to the Add your fingerprint screen.
5. Add your fingerprint
If this doesn't work, report back again.
The first one is the cheapest.
Choose Hong Kong Air Mail is good enough. No need registered mail lah.
It takes about 10 days.
