Xiaomi Mi Max
wensan
I went to security app, but I don't see any app saver of sort to click on. Can tell me in more detailed[/QUOTE]
Go to Security app -> Battery -> App battery saver
Compact7
Just update to miui 8, firtly, the very sweet heart shaped sliding buttons all gone under pink brush theme, my wife was disappointed.
2ndly the wifi 2.4G is much faster then 5G. This is very obvious drop from 7 to 8. Any bro here facing this ?
Now thought of back to Miui 7. Which 7 got quick ball? Where can I get it?
sumkong
Aiya, last time, many bros here helped me. So now, it is my turn to return something to the Bros here who need help. In fact, a bro here actually gave me this tip about preventing app to close automatically. I just made it more details by using photos.
I am Glad that I can help all here. Cheers.
sumkong
Go to Security app -> Battery -> App battery saver[/QUOTE]
It is there. Are you on Miui 8 beta? I am and I can see it.
radiancez567
The case I am using is this one with the i-Ring.
With this way, I can reach further and yet the phone will not slip out of my hand.
Can get the case from here.
Do take note that this case will have cover for the 3.5 mm audio jack and the micro USB port also. If you don't want them, just cut them off.
NOTE : At the espense of better protection, this case makes the phone feels thicker.
Item : Xiaomi Mi 5 / Mi Max Hybrid hard shockproof matt back cover
Price : About SGD$3.70 (Mi Max)
Source :
http://www.ebay.com.sg/itm/182211484774
As for the i-Ring behind.
Item : 360' Hook metal ring stand holder mount finger grip
Price : About SGD$1.40
Source :
http://www.ebay.com.sg/itm/360-Hook...hash=item3d1e8100f9:m:mnOR-Zs64VsqIJLV-v6bT8A
Thanks i1magic for the recommendation. Just received mine from Aliexpress, and it's pretty good quality for just about $3.70 :D
touchme
High time, we be moved to dedicated xiaomi forum next week.
Then the MIUI sexperts here and other xm devices, can combine forces there.
jazzman80
if volume matters, just downgrade from 8 to 7.
once again, I'm on miui 7.3.14. so far so good.
kelvinti
Awesome! :s22:
It's about time! :) Thank you, Sir!
Nakedtoes
safe to get export set? any shop recommended ?
Safe or not u read this thread u gauge yrself lor.. There are export sets with 1 month or few months shop warranty.. N if u scare get local sets with 1 yr warranty. N one think to ponder.. Do u drop yr phone often? If screen crack u think warranty got use?
Mi Max definately much safer then note 7 which will explode one.. Think abt it
jazzman80
switching to new hp used to be my bad habit as i was making loss every buy and sell.
hopefully I don't get tired easily with this mi max, till a better successor comes.
