Xiaomi Mi Max
trichard
Anyone know how to enable quixkpic apps to move file from internals storage to sdcard ? Android 6 block...
hwarzoner
Anyone on M1 and experiencing the MyM1 app crashing? It worked until I logged in then crashed... Can't check my data usage without that app... :(
my 32gb mi max can use the m1 app so far so good, maybe u wanna reinstall again the apps
azbyza
That's seller custom/modified ROM aka China ROM with 'Global' text description, so no OTA updates.
Since no official global for your 64GB, either:
A) Stay on current MIUI 7 ROM without OTA updates or
B) Flash to China stable/beta ROM and install Gapps separately or
C) Flash to EU ROM.
I too have modified Rom for my 128GB xm. I wonder why the seller don't just simply install Google Play Store on a China Rom or global beta instead of modifying the Rom? I guess they are using some sort of XDA Rom.
cscs3
I think those modified rom already has Goole Play Store pre-installed. Those has China rom then install Google play has mix result.
touchme
Is there any way to returning to miui7 single-line horizontal browse toggles on miui8 tiled?
anirudhks
as india has started seling the 128GB model now , we should have a global rom soon .
India is selling it for ~S$399
kelvinti
Hmmm...Our 32GB Mi Max has not gotten any further Global offcial rom update since the 8.0.1.0.....:vijayadmin:
