Xiaomi Mi Max
KalTorak
It says
Andrioid version 6.0.1 mmb29m
Andrioid security path 2016-05-01
MIUI version - MIUI gloobal 7.3 | stable 7.3.14.0.0 (MBDCNDE)
Its a 64gb set with 3gb memory
That's seller custom/modified ROM aka China ROM with 'Global' text description, so no OTA updates.
Since no official global for your 64GB, either:
A) Stay on current MIUI 7 ROM without OTA updates or
B) Flash to China stable/beta ROM and install Gapps separately or
C) Flash to EU ROM.
SPEED
It says
You are using a non official china rom.
Its a modified rom.
Recommend you to flash to china official rom.
HeeroYuy84
C) Flash to EU ROM.
Its a modified rom.
thank you gurus, will i lost my data ? any guides which i can reference?
is the new rom better?
trichard
Hi.. may I know what is the official Xiaomi rom currently is ? Just to make sure no 3rd party rom on my set..
michael_thm
Anyone on M1 and experiencing the MyM1 app crashing? It worked until I logged in then crashed... Can't check my data usage without that app... :(
