Xiaomi Mi Max
ngbc
or anyone has any idea is there a shop that offers DIY service of sticking the SIM card onto the SDcard?
i tried recently, but failed.
http://forums.hardwarezone.com.sg/104064734-post6861.html
4G小卡延長線
For those who are worried can look at the comments in the link page.
http://e22a.com/h.0wJIDW?cv=AANHCQXu&sm=f26a3a
1982-1994
yeah i saw that method but seriously, very ugly.
i don't use casing,I like to use it naked. but thanks anyway.
csoyzx
Is your developer options on? If so, could be the show ANR processes (sth like that) option (at the end) turned on.
Ya it was something from developer option.. I disable and reboot den ok already.. Thanks bro
Intrinion
Senior Moderator
Senior Moderator
Dun you guy think 652 will comsume more power than 650 cpu?
Possible.
SD650 has a total of 8 cores (Hexacore) - with 2x ARM Cortex A72 and 4X ARM Cortex A53
SD652 is an octa core (8 cores) - with 4 x ARM Cortex A72 and 4X ARM Cortex A53
Consumption would depend on the optimisation of these cores i.e. how it would run in power saving mode etc.
MIVEC525
Just got a noosy adapter to put my nano sim..cannot go in the tray...think must get the My sim from starhub....$27 for 6 GB data..no contract....any comments?
roidred
Go for the 652 version, I think the speed and power is worth it. No, the extra A72 cores wont reduce battery life in light use/apps. Yes, the extra A72 cores will help you get more efficient battery life in heavy usage (will not require faster clock speed). It really depends on your usage.
roidred
I got my Mocolo case from China bought from Ali express. Didn't like I ordered gold colour but now I like white. Bought it expensive 6.58 USD.
Edit- it's cover
cscs3
259 for 32gb ram export set, can buy?
Think now is $249. If you have $20 coupon or 10% coupon. Effectively it is around $229 or lower. This is like $120 cheaper then those Xiaomi local set. So even with short 7 or 14 days warranty, is still good buy. Is like every 2 phone you buy. You get another one free.
kandinsky
+1
aw1007
Encountered high battery drainage by uniplayer? Anyone knows a way to disable it by default? I am on 8.0.3.0 global stable rom..
warboy85
My Yahoo Mail didn't work at first but it's fine now. Not sure what caused it. Make sure when you login you use full email address including domain as mine kept having issues eith the verification when I only types the username without the Yahoo.com.sg. Beats me why.
As for Pokemon go I'm running MIUI 8 on a Singapore phone with no root but the catching but still lags alot. Very frustrating.
other pple encounter same issue also?
