MIVEC525
- Feb 8, 2003
Arrived in 2 weeks. I ordered it before I bought the phone![]()
ok....will consider....lol
It's cheap that's why slow. If don't mind paying a bit more, got local sellers with stock on qoo10. About $11 with postage. Should get in 2-3 days.
http://list.qoo10.sg/g/415822436
anyone experience lag while playing Pokemon go? when I throw the Pokemon ball it will hang 2-5 seconds after that okay Liao. running 8.0.2.0 global ROM.
I thought that is normal? What was your previous phone? Did you encounter this also?
juz bought a 32G from Lazada, seller is smartcell. Need e experts to help in
1. my miui version is stated miui global 7.5/stable , 7.5.6.0 (MBCMIDE )
How do i update to latest version from my hp ?
iPhone se. u mean this is normal? I never encounter this before
Anybody using Mi Max on M1 or SingTel? When you are on voicecall, your data still shows 4G / LTE?
Thinking of buying mi max, need advice from brothers and sisters here.
When to buy it in Singapore
Which version / model. Eg 16g/32g/64g.global rom better, made in China or India better.warranty set is worth the extra price or export set good enough etc
As this will be the first xiaomei phone, sorry for the stupid questions.
Mainly use for normal call, Sms, surf internet some time take phot,
1. I bought my 32GB set from Qoo10. It's a China set but seller installed modified china rom with play store for me already. When I press updater, can't update though I know miui 8 already available. No biggie since I was able to install the apps I need straight away.For the benefit of those considering purchasing a china/local/india set.
Could owners of india export set or local set share if they have the same hassle as me (china set from taobao)...
1. Google Playstore and Google service needed to be installed. Quite a hassle as you cannot just download the apk and install it ( waste of 1hrs before you realize it doesn't work when adding google account fail, after factory reset a few times before giving up). You have to download an installer (1hrs to find and determine the correct choice...) created by someone on the miui forum, make sure that your computer have ADB support drivers ( an 1hr hassle of searching and making sure it work). Reasonably it should take around 3hrs to get Google Playstore working. And you will have more hours of fun adjusting permissions to figure out which are the necessary ones because miui does not play nice with google services.
2. When I am done with Google Playstore and Services, I finally got down to transfer music files from my PC to the phone. Another few hours of hassle getting usb file transfer to work because the phone decided I wasn't going to be in file transfer mode by default. Had to figure out how to change usb connection settings hidden deep in settings.
3. I realized I wasn't getting whatsapp notifications immediately. Whatsapp calls to me was not getting thru... Had to spend more hours figuring out I needed to change permissions, getting the app to autostart AND I had to figure out that I could lock the app in task manager zzz...
D: China Set - China ROM, you're on your own, either reflash to global or manual install playstore and google apps
anyone can help me root my xiaomi max? willing to pay token of kopi sum. thanks
token of kopi sum $20. anyone want to help? thanks![]()
On my recent trip to HK/SZ, observed something interesting.
Went to Huaqiangbei in Shenzhen to look for additional covers for my Max. Almost all of the shops there do not carry Xiaomi case, mainly Samung and iPhone. I am surprise because Xiaomi is supposedly one of the top selling brand in China, so I expect many shops to be selling its hp accessories. The few shops that have Xiaomi cases only carry for Mi5 and Redmi Note 3. In the end, I managed to found one from the night market in Laojie.
Guess getting it online from Taobao is the better option.
Are there any stores in the Orchard area that have a working Mi Max on display? I would like to try it out.
Thanks in advance.
