Xiaomi Mi Max
iguoh
Are you on default theme? Apply default theme and give a try.
No, the theme will affect this as well? Let me give it a try. I also noticed that you cannot use wallpaper apps to change the lock screen wallpaper. On other phones, the app will ask if you want to change the lock screen or home screen wallpaper. I am beginning to notice little quirks with MIUI.
algerr
Seems that Smartcell(Lazada) is increasing price recently... from $249 to $265.... what's happening... =(
hummer
Hi,
Planning to purchase a 32gb set for the MIL.
Anything to watch out for?
Global ROM, MIUI 8 (how to tell?)
Difference between India and China set......
I saw some sellers in Qoo10 flogging these for about $250 to some sellers $350-ish for same capacity. Why the difeerence siah.
P R N D
Hi,
Sealed Box front cover with English print words, should be global set.
Read the review and questions being answer by seller.
Sent from Asus ASUS_Z017DA using GAGT
cscs3
Hi,
That's the beauty of web purchase. Just like shopping at real shop. Each seller has their own target for profit margin. Sometime goods actually from the same master supplier. (Very similar to those mom marketing).
noobzpro
Is ziming global the cheapest for 32gb at 244 with 6 months warranty? Thanks.
maxin76
Joined as its Follower, you can apply its $5 Store Discount off. Price becomes $239/-
And if you sufficient QPoints, every 100 points = $1 (limitation applies). More savings......
