Xiaomi Mi Max
MIVEC525
iguoh
Carousell app notifications
I cannot seem to get any notification from my Carousell app. I already tried these:
1. Put the Carousell app under Custom in Power Saving Mode.
2. Allow Autostart in Permissions.
Despite the above, if the Carousell app is not running, there are no notifications even when someone messages me. Has anyone found a solution to this? Thanks in advance.
kandinsky
curious, how the no-camera zones administer the front cameras?
Grinded/scratched/sand-blasted, and pass a sample photo test.
Has anybody read it yet? :D
Only personal mobile phones with Hardware disabled cameras are allowed into red zones.
Hardware disabling guideline are
1)All camera(s) shall be physically removed , such that the personal mobiles phones and/or smartwatches can no longer capture images; or
2)All camera lens(es) shall be grinded or sand-blasted, such that only completely blurred images can be captured by the camera(s). The grinding or sand-blasting must be done on the actual camera lens and not on any other removable camera lens cover. The camera(s) shall conform to the grinding/sand-blasting standard stipulated in Annex A.
The only document you need to have is Self-Declaration form signed by yourself and your unit security officer. 2 copies , 1 kept by useco 1 kept by you.
Else as long as your camera lens is either removed. Or your camera captures images that are so blur that it cannot be discerned.
The example in the directive is Font Size 300 letter A , that cannot even be recognized with camera that is A4 size paper distance from the Image.
kandinsky
I wonder if this might be an app problem, I had this issue with my previous non-xiaomi phone also. If the app doesn't run in background, nothing it can do. One thing you can do is turn on email notifications, so at least you have that when someone messages you.
roidred
Are you on default theme? Apply default theme and give a try.
Plastick
are there users out there who flashed to global stable from global beta rom? and why
Yuripa
Hi guys, currently a note7 user here.
Just wanna check if I should be buying from lazada and try to wait for promo coupon to offset the rrp of $349 or purchase it at ms at $320 if I wanna get a local set with warranty.
Many thanks in advance..!!
Ps: Where do you guys get ur accessories too? I'm intending to get a normal matt sp and a sprigan type back cover that allows a card slot for my ezlink card.
Sent from Nokia 8600 luna edition using GAGT
