Xiaomi Mi Max
Compact7
Depand on how you weight. Local or export, both is MAX the best. Only you surely can get xm sg free fix within a yr for the local set. If you like me, want a phone use more than 1 to 2 yrs, then local is peace of mind. I think there also a lot happy owner used export set for yrs without issue too.
Btw, the latest MiUi is superb. It really save power when standby. Also the ram usage is optimised too.
For thom worry or encounter ah max poke your didi in your jean while walking or stting, you can sewing your inner pocket at the upper part there to stop it slide in to poke your didi. Very easy to do one.
i1magic
Yah. Those that want warranty support, just get local set.
Yes. MIUI is really good. I find that they are fast and lean.
kelvinti
Ya. Huge in hand but I tell you what... You will love it coz everything will be big on screen no matter what apps you open and the keyboard is huge and it is good for typing. So comfortable.... :)
Having said that the handset is huge. You will get use to it on how to hold it tightly on hand and operate it with 2 hands as well as how to slot it in and out from your pants pocket without any fear of dropping the Mi Max. :)
A minimal thin tpu casing is a must for Mi Max. It helps to cushion any drop impact as well as knocks impact. :)
I have dropped my Mi Max twice onto the wooden floor and the thin tpu casing helped to protect the Mi Max especially the corners.
kelvinti
I just weigh my Mi Max with the thick case .... weighs about 291g. :s22:
Nice! :s13:
As heavy as my tiny gold bar that I have just bought this noon! :s22:
I'm using a 0.3mm ultrs thin transparent TPU case. It adds just 1 gram extra to my Mi Miax! :)
kelvinti
Mi Max is till the best after so many months if one likes to watch video / dramas and YouTube on the go...or simply to watch anything, anytime... :)
The 6.44" huge display is simply stunning and such a joy to do so...
No substitute for it. Period.
Those who are still standing on the edge, please hesitate no more.
Go grab one since the price is so reasonably low.
Don't forget the huge 4850mha battery as well. :)
You can believe no one but you have got to believe me as a 3rd time Mi Max owner bah. :)
Win win situation. :)
knightcover
Bro, me really 佩服you, eat 3 times 回头草
Sent from Xiaomi REDMI NOTE 3 using GAGT
kelvinti
cheapest export set with india?/global rom :) 3/32gb model
Go search Lazada and Carousell... Quite a few below or around 250 brand new now..
It can either be an export Indian or Malaysian with global rom now...
Qoo10 are 99% China export set with China rom... Troublesome and price also almost the same as Indian and Malaysian... :(.
