Xiaomi Mi Max
w3nj13
Anybody using microsd card? I can't seem to fit my microsd into sim 2 slot, hence can only fit into sim 1 slot, making my sim card in sim 2 slot, and only has H+, NOT 4g connection? Anybody has any ideas how to get BOTH microsd card and 4g connection?
Computeron
how can that be?
edmund_gan
Bro.. u mean u want dual sim connection and SD card at the same time? You can do that..just Google but u may need to sacrifice one sim card if all dun goes well..
Audiology93
Either (1 SIM AND 1 microSD) OR (2 SIM AND 0 microSD). But if you only have 1 SIM card, then the microSD card should fit into the slot. Try turning to the other side.
Sent from Samsung SM-G935F using GAGT
lmf2501
What case is everybody using? mine's a transparent ribbed casing pass to me by seller, looking for something thats not book type or silicon
w3nj13
Thanks all for replying! What i meant was I want 1 sim and 1 microsd card! I can only insert microsd card into SIM 1 slot, while my main sim card is in SIM 2. There's no orientation where microsd card would fit into SIM 2. The question is if only 1 sim card is in SIM 2 slot, will it have 4g+3g or just 3g?
Oinkize
If 1 sim then depending on your operator's coverage lor...
garychengjw
if 2 sim = 4 + 3 g
any sim on any slot = 4g (+1sd card)
jowy_ham
Where to buy Mi Max 64GB version besides via Taobao/Tmall ? Lazada dont seem to have leh
How much is it (64GB version) ?
