Xiaomi Mi Max
virus2977
mine china rom miui 8 got Xunlei download accelerator. Gobal rom don't have this thing rit. I download file very fast.......lol
DarthGW
can i flash from developer rom to global rom?updater dont allow me to change
Oinkize
They should mah since Mi Max 32GB is locally available and it is an official handphone model with 3 telcos here.
64/128 variant might be a different story then...
No diff. I think all XM phones dun support volte in sg.
bladez87
Yes. You can only update to stable rom 8xxx, not 6.xxxx Developer rom... :)
how to switch between developer rom and stable rom?
also do i need to unlock the bootloader for my phone to do all these?
anyone unlocked their bootloader?
kelvinti
No need to unlock bootloader.
You need to use the miflash method using a global Fastboot rom.
It is going to be a total wipeout method. You have got to set up your phone from ground zero after flashing.
bladez87
did you unlock your bootloader?
what is the point of doing so?
any ideas how to root?
thanks
kelvinti
thanks
I don't unlock my bootloader as I don't root. :s22:
Rooting allowed you to install 3rd party customized ROM be it MIUI based on non-MIUI based ROMs or to be an official Alpha ROM tester by XIaomi MIUI Teams. :)
To root, refer to below link. I have never rooted my Mi Max. So, root at your own risk hor! :D
https://xiaomi.eu/community/threads/6-12-1.36462/
wawa33
transfer photos, video to notebook
hi bros, any one can share how to transfer photos, video to notebook's hard drive ?
newbie using mi max . tried connecting the cable comes with the hp to my notebook but unable to transfer and my notebook shows the device is locked and empty file . . dun know why ?
KuroI-Kaze
Update your firmware to the latest available to see how it goes...:)
Tried, it says no updates available.
In the end I went back to the shop the guy there can't fix it too. So he 1 to 1 exchange for me.
But I still have a problem, my miui ver is 7.3.15 mbccndc so by right there is a newer version for me to update. But when I tried to update it says no updates available.
kelvinti
OIC! Gotten a lemon WiFi on your original set ahh! :s8: :D
I think if you are still on MIUI 7.3.x.x, you will not be able to get any updates already coz I think that MIUI update server no longer registering Mi Max that are still running damn old Miui 7.3.1.5 to be eligible for update liao!
The best solution is to download the latest MIUI8 V8.1.3.0 (http://en.miui.com/thread-411378-1-1.html) Recovery ROM, copy to your phone and use the "Choose Update Package" to update. :)
However, if the above-mentioned method failed, then you have to do this:
To miFlash the latest MIUI8 V8.1.3.0 (http://en.miui.com/thread-411378-1-1.html) Fastboot ROM in order to "catch up" with the update schedule...:s22:
This will be a total wipe out method. After flashing to 8.1.3.0, you have got to set up from ground zero!
Other Xiaomi / MIUI gurus here may have a better solution to your problem. Please advise Kama-Kaze bro for any alternate methods that can avoid a total wipe out Fastboot ROM method that I have suggested. :s22:
i1magic
If you did use fingerprint unlock, you'll need to unlock the phone after you plug the cable in.
This is a security feature. So if somebody who got your phone and just plug in, they cannot access your phone to copy anything out.
