Xiaomi Mi Max
bladez87
donno whether to root my phone for 1 app only. anmoney. i can live without poweramp but anmoney is pretty important. sigh.
adamis
hi bros, any one can share how to transfer photos, video to notebook's hard drive ?
newbie using mi max . tried connecting the cable comes with the hp to my notebook but unable to transfer and my notebook shows the device is locked and empty file . . dun know why ?
Look at the Mi Max notification panel after connecting to PC.
From there click on the notification showing USB for charging connected, and change it to the one that allows file transfer (MTP).
localITguy
Suspended
Guys. If you are having issues receiving notifications from certain apps,(eg: Pushbullet)
Disable the permissions manager completely and that will resolve all notifications issues
Enable developer mode> additional settings>
Developer options>enable>
Scroll down and turn off MIUI optimization
Reboot device
Open security app>permissions>Gear icon>disable the first option.
The permissions manager is junk anyway..
kelvinti
Reboot device
Nice tip! :s22:
I just did it! Thanks! :)
shuvit
Got example of screenshot for your message? :eek:
Don't have. It just trigger a error report to Xiaomi team
I rmb got one bro also same problem but I can't trace back the thread
Only when the font is small, then problem resolved
Font XXXL then can't open messages
azbyza
Recently, Hardwarezone added an advert strip on the right hand side of the screen. It's huge and using up 20% of the whole screen. It's irritating also, flashing the screen with animation.
Anybody knows how to turn it off? This is already bad on huge MiMax screen, I wonder those using tiny iPhone screens, how could they read the screens? They probably gotta keep expanding and scrolling. Must be tiring and only die-hard Apple fans would suffer and smile LOL.
KuroI-Kaze
OIC! Gotten a lemon WiFi on your original set ahh! :s8: :D
I think if you are still on MIUI 7.3.x.x, you will not be able to get any updates already coz I think that MIUI update server no longer registering Mi Max that are still running damn old Miui 7.3.1.5 to be eligible for update liao!
The best solution is to download the latest MIUI8 V8.1.3.0 (http://en.miui.com/thread-411378-1-1.html) Recovery ROM, copy to your phone and use the "Choose Update Package" to update. :)
However, if the above-mentioned method failed, then you have to do this:
To miFlash the latest MIUI8 V8.1.3.0 (http://en.miui.com/thread-411378-1-1.html) Fastboot ROM in order to "catch up" with the update schedule...:s22:
This will be a total wipe out method. After flashing to 8.1.3.0, you have got to set up from ground zero!
Other Xiaomi / MIUI gurus here may have a better solution to your problem. Please advise Kama-Kaze bro for any alternate methods that can avoid a total wipe out Fastboot ROM method that I have suggested. :s22:
thx for your advise, but the link u gave is china rom? Not global?
Oinkize
It is not showing up on mobile view. Try using mobile view instead?
virus2977
Tried, it says no updates available.
In the end I went back to the shop the guy there can't fix it too. So he 1 to 1 exchange for me.
But I still have a problem, my miui ver is 7.3.15 mbccndc so by right there is a newer version for me to update. But when I tried to update it says no updates available.
I bought mine max from china also got this problem....miui 7. It cannot update to miui 8. Need to use computer to install miflash program to flash the phone to miui8. This link help me to solve my problem.
http://en.miui.com/thread-307139-1-1.html
kelvinti
I guess that using the Fastboot rom miflash is the only method now in this case in order to go up to 8.1.3.0...
kelvinti
HardwareZone side and bottom advertisements are so irritating.
It slows down and at times, jammed my typing in the forum threads. KNN indeed... :(
SkimMilk
Guys, what are u using to protect screen and handset? Links and reviews will be nice. :D
kelvinti
Masterpass crashed in max ....
Ya... Few crashes in MIUI...
Afterall, it is still a Chinese based firmware...and that's the problem depending on what apps you are using....
MIUI is still a not so international standard friendly in that context....
However, thanks God that Android Pay and all banks mobile apps here are working fine.
KuroI-Kaze
I tried the tutorial and miflash gave me a "cannot read from port COM10" error ...
Edit: Managed to flash successfully, thanks Bro Kelvinti & Bro virus2977
cscs3
Actually is quite complicated. They are actually base on CM, translate to Chinese. Then modify to English for global market. This is why they are slow in Android version or sometime none. Worse is English global version is always lacking behind Chinese version. Sometime by multiple level.
