Xiaomi Mi Max
allanzzz
Finally manage to have 2 SIM and SDcard at the same time.
The device protruding out is thin enough to fit on a soft case. but i doubt will work on a hard case.
No need burn SIM card or super glue, just the device and a double sided tape
i1magic
Wah .. where you bought this? Can share link? So it'll be still dual SIM standby?
Actually, I would cut a hole to cater for this. Anyway, the flat surface part doesn't really kana much impact most of the time.
MIVEC525
any link? Where to get?
Oinkize
How much and where did you buy it from?
