Xiaomi Mi Max
Starbutt
sorry can i check if its too difficult for 1 handed usage? im contemplating btw this & xiao mi 5. thanks.
I have same concern but I may buy those kick stand ring to stick behind the phone so my finger can slide into the ring for reinforcement.
You can go Challenger store to test it out first before buying online.
Sent from Xiaomi MI 4I using GAGT
Bobby Goh
Those kickstand ring (aka iring) is very useful. Last time, I used to buy together with my other purchase because the cost is low, good for when you need to make up to $50 and need only $1-$3.
Now finally found a use for it.
allanzzz
Nakedtoes
There's the quick ball feature really helps. I can use it one hand for most basic stuff like browsing, reading, back/home, etc., only when want to type stuff then need two hands.
Try pie control.. Much better then ball. Basically when typing then I need use both hand.. Else dun need at all
merlot6230
google play alway hang or unable to use...reset few time.
error msg ? Error retireving information from server RH-01...retry
kelvinti
Anyway, 8.1.6.0 is officially a Beta Stable for Mi Max Prime now... :)
However, I wasn't being pushed again. :(
kelvinti
Finally made up my mind to join the Mi Max family.
The interesting part is so many brothers here are so helpful
in sharing knowledge and techniques in maximizing the usage
of this wonder phone.
Long live the Max.
A BIG Welcome, bro! :)
Devilsire
Mi Max, no regrets!
although im quite tempted with better cam & NFC feature
