Xiaomi Mi Max
kelvinti
will leave those sticky residue?
Not much depending on your peeling skill bah..
Anyway, just put a little bit of water or your siliva on your middle finger to wipe it away. Very easy and simple. Nothing to worry.. :)
kelvinti
The only thing I backup and to McCloud is the Note app. :)
The rest are not important.
skrw105
ota for global stable 32gb rom.
zelot80
sorry for this noob qns but do u peel off that warning sticker on the back of the phone:o
although I do feels like peeling off and put it in the box. but is it alright?
if you have lighter fluid/liquid.. pour some on it.. like it soak for ard a few seconds... it will come off easily.
anirudhks
i am back on the max club again , after getting tempted to run the CM14.1 with the google assistant :p.. honestly left , returned ,left returned, this is a solid hardware for the price .. hehehe
azbyza
Thanks.i thought i read somewhere it work without headphones..
If you don't want to carry a headphone, then you can stick an INSULATED WIRE into the headphone hole to act as an FM antenna.
Remember must be INSULATED WIRE to avoid shorting the circuits inside. I use those insulated wires that are used for tying plastic bags. Choose one of about 10cm, turn one end into a very small u to fit snugly into the hole. Experiment to find what works for you.
I do this to avoid the floppy headphone wires flipping to the front and blocking the display. Then I use Bluetooth to cast the FM radio output to my speakers to listen to music while I surf.
I have tons of mp3 on my phone but got bored with the predictability. Radio still have more.
kelvinti
Found a same same but different specis here... Kekeke.
allanzzz
For those that root, do you just dirty flash or do all the settings all over again. Seems like too many updates in such a short period of time.
Oinkize
yes Kelvinti bro , I follow you from the GPro 1 and G Pro 2 forums hahaha.. I infact had one forumer sell me his G pro to me saying its Kelvinti's G Pro haha :s13::s13::s13:
Wa, it's like swapping underwear sia...
Bff...
linbeier
not sure if it's just me but my mi max screen becomes less responsive at sub 15℃
