Xiaomi Mi Max
danheng
hi all, jus placed an order for the giant, 128gb version.
hope to learn more with all the seniors here...
anxiously awaiting for the arrival.:s12:
danheng
Wow! Nice! :)
tks bro..... anything to look out for?
am apprehensive abt handling such a big phone.. lol...
it'll be my secondary phone/tablet, hopefully dun give me 2 much headaches, as it only comes with 1 mth warranty...
kelvinti
Get a casing first. A tpu case would be minimum. A screen protector is optional but highly recommended if you are afraid of dropping thus breaking the screen. That is good enough for protection.
Flash to global rom if it comes with China rom before you start to set it up.
Deep pocket pants is really needed.
danheng
according to other buyers, the seller will flash to global rom,
fingers crossed...
kelvinti
oh soli. forgot I'm on china ROM.
into my 5th month of using max. still with 32GB.
Haha!
Considering an upgrade from 32?
You can sell the 32 to fund the 128 as the price is pretty reasonable now. Kekeke.
yusoffb01
To those having ads, this is the culprit
Hmm I realised cannot disable or hibernate system apps or it won't boot. It is really built in tightly into the rom, unlike other manufacturers.
nasilemak100
Nice try, but that's not the case for nasilemak100. If I'm not wrong, he should be using China ROM which has the download limit set to (default) 10 MB. This literally limit most app download.
Nasilemak100, you need to go to Tools > Download > Settings > Set download limit to unlimited.
This should work.
Sent from Fantasy Island using GAGT
Thanks a lot! it worked :s12:
ceestudent
What screen protector do you guys use?
I'm using tempered glass now, but notice sometime need to press harder when playing game. Plan to change to normal film.
Anybody know where to buy clasy brand film?
ch1234
Can't seems to find it on global ROM. Maybe global ROM dun have :s11:
yusoffb01
Those with low volume problem can try disable this settings/installed apps/musicfx
yusoffb01
strange, when i got to that screen, the Force Stop button is enabled but the Disable button is grayed out.
unfortunately for miui 8 it doesn't allow disable. But if you're rooted, there are other ways.
