Xiaomi Mi Max
ccn666
SD650 vs. SD652
Qualcomm Snapdragon 650
Hexacore = 2x ARM Cortex A72, 4x ARM Cortex A53
Qualcomm Snapdragon 652
Octacore = 4x ARM Cortex A72, 4x ARM Cortex A53
Benchmark-wise (Antutu), SD652 is slightly faster than SD650
Xiaomi Mi Max (SD650) = 68,200
Samsung Galaxy A9 Pro (SD652) = 70,932
But in real life usage, you won't be able to tell any difference because almost all apps are not optimised to run on more than 2 cores. More cores will only help make multi-tasking slightly more responsive, so IMHO, there's really no point spending more money to get the SD652 because both SD650 & SD652 are running at the exact same clockspeed (max 1.8 GHz).
2 extra cores if I'm not wrong
I don't feel any diff.
Sent from Samsung Galaxy S5 (RestructionRemix ROM) using GAGT
zeroflame
Global rom coming soon?
zeroflame
singapore just launch Mi5...don't think will so fast release here.
But for those like me who already bought it..global rom soon ;)
i1magic
is there significant difference between 650 vs 652?
Don't think there will be significant difference. But if the pricing is really close, then might as well get the SD652 sets right?
Unless the pricing is too big, then no point.
anirudhks
Depends on storage n sim usage if you are someone who needs more storage same time wanna use 2 sims then 652 is a better option as inbuilt u get 64 or 128 for 652 and u can use 2 sims. But for 650 u get only 32 gb so more storage u add sd card u loose 2 sim options
lmf2501
kena twice liao, reboot the 'extras' will automatically be added as shortcuts to my home screen LOL
bbcccc
Yeah!
India first ... then to our Little India soon...! :)
It has to be Global ROM then!
It's time! Cool!:s22: I have got to put aside $350? Enough?
looking at mi5 sg price, likely $399 for 32gb model...
Ike777
Hooted one set from Lazada. Total damage around $310 (including one transparent case and 2x glass protector from taozi). The protector from Taozi do not fully cover the phone. Any source for full coverage glass protector for Mi Max?
