CrucifyMyLove
- Dec 9, 2005
Yay!! i gotten the permission to unlock liaoz.
No this is first timeHave you unlocked a device previously? If yes, 30days unlock once .
Sent from Samsung Galaxy S5 (RestructionRemix ROM) using GAGT
Were able to unlock? I keep getting cannot verify deviceYay!! i gotten the permission to unlock liaoz.![]()
Had the same problem before. I disabled "Wake lock screen for notification" then no more problem liao.when I try to use the fingerprint sensor when the screen is off, the screen will momentarily turn itself on, then turn off again.
As time goes it will be further improvedSo, this phone is still not stable in terms of its firmware it seems.
Wanted to cfm...
SD650....3g Ram in either 32gb/64gb
Sd652......4g Ram in 128gb
weird lei
updater shows my 64gb 7.3.15 is latest whereas wifey de 32gb already 7.3.16...
maybe tml try again...
Wahhh lucky u.. Did you enable anything like usb debugging or oem unlock in dev options?can leh. i unlocked liaoz
