Xiaomi Mi Note
jianhui777
i am able to help,
based on a 64gb version of 2999 RMB
formula as per 3000 RMB ( credit card charges ) + 25 sgd.....
limited sets as max i will ask him bring 2 phones back .....
good luck in securing one.
I tried 3 weeks... unable to even order 1, even though I login at 1145am, waiting to 12pm sharp every Tuesday.
There are simply too many china farmers, buying to resell it.
Sent from Xiaomi MI NOTE PRO using GAGT
slowpokie
My chinese is bad....
tot preorder and pay only ???
jianhui777
Just like iphone6 Pre register interest, only those Pre registered the week before can purchase on Tuesday.
Problem is demand much much greater than supply
zenithfl
i am able to help,
If not mistaken, your cart will only able to secure one at a time, don't think he can get 2 in the same week, correct me if I am wrong.
zenithfl
Indeed there was a pre-order option 2 week before, but was very very limited unit, where you order and pay and get in 4-5 weeks instead of snatching with farmers and deliver within 1 week.
sunht
Tried to pre-order mi note pro yesterday, my understanding was before every Tuesday , you can pre-order. Might be wrong . I didn't success in the end, it needs local number for registration, was too late to call my China friend. Will try today before tomorrow's actual purchase.
calvinhan
If you dont mind waiting, you can choose 顶配版 and then 预售. You dont have to fight with the chinese farmers with this options but they will shipped the phone in 3 to 4 weeks times.
Good for those if you are not in a hurry to get the phone.
sunht
Is it pre-order you mentioned? If yes and If I understand correctly, pre-order will not secure your purchase, it is just give you a chance to purchase, may still not able to get one if you are not fast enough.
calvinhan
nope..if you choose 预约开放购买. it means that you are fighting with the farmers every tuesdays but shipment will be fast if you are able to get one.
if you choose 预售, it means you are CONFIRMED one set. only set back is that you need to pay for it first and only get the phone 3 to 4 weeks after placing orders.
Some ppl are not able to wait so they rather fight with the farmers while some dont mind waiting will choose the 预售 option.
sunht
I see. Thanks. Btw, which model (联通/移动/电信) to get in order to be functioned in Singapore? I think no international warranty from xiaomi right?
hksin
For mi note and note pro, it support both LTE-FDD and LTE-TDD. No model to choose
If buying other model (redmi, redmi note etc), you need to buy 联通 for LTE-FDD support which is similar to Singapore 4G.
sunht
Thanks bro.
sinmarket
just my opinions on mi note 64GB
very disappointed with the phone.
When using the original firmware out of the box:
Problems:
1. Cannot voicecall on whatsapp, Skype
2. call voices not working when using earpiece.
3. cannot update the firmware over the wifi.
Sent to china Xiaomi china and they reflash with new and simpler firmware for me.
Problems now:
1. difficult to unlock the phone and message always appear to warn me not to cover the top part.
2. when using the phone in call mode, the screen saver will turn off the phone screen and it is very difficult to turn back on the screen.
other than this the phone work great.
pictures quality are acceptable.
voice clearity is better than my ip6.
may want to try to reflash with different firmware.
any suggestion?
JuXn5566
Problems:
Problems now:
any suggestion?
Firmware can always download from en.miui.com/download-262.html and guide is available too.
Your problem seem to be your screen protector blocking the proximity sensor. Remove it will solve both problems.
Devilsire
Problems now:
any suggestion?
1) Is your screen protector / tempered glass covering the proximity sensor? :vijayadmin: if not, u can choose to off the Proximity sensor (under Call settings > Incoming call settings) and the Pocket Dialling setting till u figure out what the problem
2) Same as above
sinmarket
Thanks for the advise.
The screen protector is not blocking.
Anyway got to off all the setting and hope it does not bother much.
Another problem I have, previous MIUI work with my LG R watch.
My current MIUI 6.5.4.0 does not work.
Anyone face this problem?
Or which MIUI is good to have?
Thanks
2) Same as above
sinmarket
I did proximity calibration and seem solve some of the problem.
for those need to calibrate proximity sensor
dial
*#*#64663#*#*
it will go to the test mode.
2) Same as above
