Xiaomi Mi Note
Bulletbreaker
Wah was about to get this, read some of the bros comments here, im better off with other phones.
hksin
In china, MI Note price just dropped to RMB 1999 for 16gb model. They will also be releasing a new 全网通 model on 7th Jul. (previously only 双网通)
But their release in Singapore is way too slow.
sunht
if buy there and use in Singapore, is it 联通version compatible to all three telco here? Or need to buy 全网通?
zenithfl
Now Mi Note were all 双网 (联通 and 移动) is just like our local phones, except for 电信. 全网通 will include 电信. So no concern if to use in Singapore.
smarterence
Hi there, am going to Hong Kong in August. Can I buy in Hong Kong retail shop or still have to go through their XM website? Any body can share experience?
sunht
Thanks, so no need getting 全网通 to use here, can save some dollars.😊
oakley
Xiaomi Note Pro dual sim support bands
Hi guys,
Anyone knows what is the dual sim support bands?
Like SIM 1 support up to LTE and SIM 2 support up to 2G/3G or what?
sunht
Now xiaomi china website no need pre-order for note pro. But heard note pro got some heat issue , now considering to get note or note pro (1000 rmb difference) ? Any advice; thanks
oakley
Both slot supports LTE, can change through miui software, but only 1 slot for LTE and the other slot for 2G only, this is always the case for dual sim dual standby phone (since only 1 antenna).
Dual sim dual active phone with 2 antennas can do both slot LTE at the same time, but now only limited to qualcomm x10 or x12 modem only, and very difficult to find.
LG G3 D858 is such phone, but its TD-LTE.
http://gadgets.ndtv.com/mobiles/news/lg-g3-d858-with-dual-sim-support-launched-574739
So both SIMs cannot be running LTE at the same time? Which means SIM2 will be running at very slow rate.
Is there any way we can confirm this?
Seifer28
SIM2 is only for calls and SMS essentially.... there will not be data transmission on SIM2 when SIM1 is using the data module in the phone
oprahsbs
can anyone shares me apk for minote pro? tried to install, but play store refuse to open. :(
Seifer28
download aptoide
den download google installer from aptoide (red logo with half an android robot icon)
this will give you all the google apps you need
