Xiaomi Mi Note
ongbahk
Hello all...just to share, I got my mi Note this week, purchase on Lazada (Novel Communication), and got it on Wednesday. All in all I paid
$535 - $30(MasterCard Monday) - $ 13.37 (shopbak) = $491.63
wildfaye29
Yes. Dual Sim standby is supposed to work this way.:D
Depending on phone model. He may have to put data sim at sim 1 position.
Yes, Mi note works this way with no restriction on which slot put what card.
Sent from Xiaomi MI NOTE LTE using GAGT
lol, Mi Note's both supports 4G SIM, no restrictions like the Redmi 1S etc.
Sent from Xiaomi REDMI 1s using GAGT
Thanks all! :s12:
Just Me
Is it agent or shop warranty?
wildfaye29
The Mi Note does not have the Mi radio app.
Is there anywhere I download the radio app. Use antenna one, not data radio app.
Thanks in advance!
Kent110285
Hi there
Just started to used Mi note yesterday... Can some kind soul tell me y this happens and how to solve it?
A lock sign beside the app inside the task cleaning page.
rharish_21
That is to prevent the app being killed when your clear all the apps..
If you don't want that to be preserved, just pull it down one more time to unlock it.
savage
it means it is marked as an app that won't be cleared when cleaning up recent apps. you can undo it by swiping the opposite direction of clearing it.
savage
Sure, but it used up you data plan vs free from air.
aiyah it doesn't really use up that much. Unless you listen from Morning to Midnight.
I listen to internet radio everytime I travel to and fro for work. barely takes up a few hundred mb per month.
and also underground also can listen :)
Kent110285
Thanks, it's gone after shut down and on back again. Why is this happening?
ongbahk
just checked with mi Singapore via their facebook page. :s22::s22::s22::s22::s22:
