Xiaomi Mi Note
geckoSG
Anyone encounter issue with Google MAPS where you keep having searching for GPS?
Android version: 6.0.1 MMB29M
MIUI Global 7.5 | Stable 7.5.1.0 (MXEMIDE)
Whether I use the High Accuracy or Device Only, I still cannnot get after 20minutes.
Using both Starhub n M1 Sim Card.
Oinkize
Have you tried to reboot the phone or uninstall Google maps?
Oinkize
My mi note went into bootloop today after flashing beta rom. Now trying to flash via fastboot without losing data and see if it works...
Oinkize
In the end have to flash with all data loss. Lucky backup done.
Now restoring back...
Oinkize
Tried Liao. Still not working. GPS test can find satellites but do not see locked on
Weird. It happened to me once but after uninstalling and reinstalling google maps it works...
You might need to factory reset your phone if worst comes to worst.
geckoSG
Need help from Mi Note owners, can someone try to install fallout shelter game and see if your installation crash? I can't install even if I do a clean reset of phone. Am on MIUI 7
amazingone
Likely specs for the successor of the Mi Note, the Mi Note 2:
SD821, curved-edge AMOLED display by Samsung, aluminum unibody, front fingerprint sensor, 3600mAh w/ QC3.0 ~
http://m.weibo.cn/1210347234/4006688460031676?sourceType=sms&from=1067095010&wm=3333_1001
Sent from my Rice phone using GAGT
Shutterbox
Guys,
any of you successfully update to Miui 8? what's your OS after update?
mine says:
Model number - HM Note1LTE
Android version - 4.4.4KTU84P
but i check the Miui 8 website and it says:
MIUI 8 Global Stable ROM Supported Devices
Redmi 1S, Redmi 2, Redmi 2 Prime, Redmi Note 3 Qualcomm, Redmi Note 3 Special Edition, Redmi Note 2, Redmi Note 3G, Redmi Note 4G, Redmi Note Prime, Redmi 3, Redmi 3S/Prime, Mi 2/2S, Mi 3, Mi 4, Mi 4i, Mi 5, Mi Note, Mi Max 32GB
JuXn5566
Guys,
mine says:
Yours is Redmi Note 4G which is correct at Android 4.4.
