Xiaomi Mi Note
mingfreakrsx
面對機皇戰,小米科技在台預告小米Note頂配版將於五月登台,(...)
"Facing strong competition(supposingly by Asus Zenfone 2), Xiaomi Taiwan will be launching the Mi Note Pro in Taiwan by May 2015"
http://www.ettoday.net/news/20150316/479204.htm
Mi Note Pro will be launching around May supposingly, maybe the Mi Note Pro will be the one coming to SG too, instead of the Mi Note.. :)
kelvinti
This is about the Pro version.
Worth to buy the Pro at $699 for an export set directly from China with local shop warranty?
cscs3
Never believe in this. What make you think local shop will stock up the part to support your warranty?
Also at $699. I would prefer to get some major brand for better OS and firmware support.
Zaalaa
too expensive for a china phone.
not affordable anymore and all features are mostly copied..
kelvinti
Ohh!
I have never tired any Xiaomi or China made producst before. So, I wanna try it, and that I think the Mi Note Pro is worth to try. ;)
dgeralds
Hi all
I was very keen XIAOMI mi note. But now it seems to me that LG G3 D858HK Dual Sim is better because:
1. Price almost same SGD 500 and both has dual SIM.
2. Smaller physical size (though display is 0.2 inch smaller)
3. Has NFC
4. Has Infrared
5. Has FM Radio (important for me)
6. How is camera quality in comparison?
Can I know your views? Thank you.
jedi5diah
Hi all
3. Has NFC
4. Has Infrared
you have to weight how much of the better LG specs you are using, mi best is the OS with lots of under hood customisation imo, camera is great but very basic features.
dgeralds
I have never used LG before. I have used only xiaomi and Samsung. Now Zenfone 2 dual sim also seems promising at a lower price.
kelvinti
Anyway,
Anyone knows where can I play with a live set of Mi Note and the Pro now?
kelvinti
Xiaomi says they are bringing in the Pro and non Pro to Singapore for sure soon.
So, I guess it is worth to wait for a month or 2 lah for a full local Xiaomi warranty.
