Xiaomi MiTV2 help
VodkaPear
I have trouble connecting my soundbar with woofer using bluetooth but no problem using cable.
Anyone have the link to troubleshoot or know what is the issue? I am using firmware 1.1.94.
any help?
or u all use the woofer cable instead?
VodkaPear
using BT connection......default setup during TV setup:vijayadmin:
tried. no use. i guess woofer problem. bar n woofer connected using BT but no bom bom sound.
guess should jus use the wire to connect.
feel damn sian now.
wlun228
Best to buy through prime, cheaper.
Anyway now all xiaomi tv price reduced(other than 48")
So best to make ur move now :)
blinux
Hello All
Can someone provide me MiTvGameCenter_T6 apk and doukantv.apk, from /vendor/app/ folder. from yours MiTV2 or MiTV3 devices, please ? It looks like my device missing this files and can't update.
blinux
Hello
I get error log of my update, maybe someone can help me with this error? Anybody have an idea what to do ?
Opening update package /data/data/com.xiaomi.mitv.upgrade/packages/package-5.1.1.915-5.1.1.988.zipVerifying update package...verify_file returned 0
Starting install package on Thu Jul 28 19:56:44 2016
matches was 2 on <</dev/fuse />>
file "/tmp/update//system/bin/debuggerd" doesn't have any of expected sha1 sums; checking cache
failed to stat "/cache/saved.file": No such file or directory
failed to load cache file
The update scripts return 1
By log it looks I need saved.file from /cache/ directory
blinux
P.S Maybe someone can provide me Xiaomi service center email ? I do not read in Chinese :(, and can't find it .
blinux
This is after second try after first
Starting install package on Thu Jul 28 19:57:49 2016
61472768 bytes free on /cache (55861952 needed)
patch /tmp/update//system/.secureinfo/tee.bin: now cb6f7ca3
patch /tmp/update//system/app/Bluetooth/Bluetooth.apk: now 1ca33e5e
patch /tmp/update//system/app/Bluetooth/arm/Bluetooth.odex: now 8d3107e5
patch /tmp/update//system/app/Browser/Browser.apk: now b5041bb5
patch /tmp/update//system/app/Browser/arm/Browser.odex: now b5185
minzip: Can't create target file "/tmp/update//system/etc/install-recovery.sh": Operation not permitted
minzip: Extracted 0 file(s)
wlun228
Question
How to reboot xiaomi tv ?
Sometime kodi/pudding might fail, so need to reboot the tv.
But I tried off and on back. No different.
Any other method ?
Currently I'm switching off the tv and then switch off the power as well.
Wondering if there's other method without the need of switching off main power.
Stallone
