Xiaomi MiTV2 help
VodkaPear
Need some help..
I just received my soundbar and woofer to be used with my samsung tv.
Currently i using miotv as well as apple tv which connected to my tv via hdmi.
Ytd, I connected my soundbar to my tv via hdmi too.
If I want all the sounds to directly output to my soundbar, is that possible by this setting?
Or, I should have connected my miotv and apple tv to my soundbar instead?
Because duno is it me or what, i felt that if miotv and apple tv connected to tv directly is more swee as compared to connect it to the soundbar.
Another qns. I tried to use my iPhone to airplay to my soundbar. From my phone I can c the soundbar as one of the airplay device. I can connect to it too. However, there are no sounds coming out form my soundbar. What do I miss out in the setting? or I need to press some function?
Last qns, I tried to connect my soundbar to woofer using bluetooth. Can successfully sense and connected. However, if i play songs using the youtube app in the soundbar, there is no bom bom sound from the woofer.
Therefore, I tried to connect my soundbar to the woofer using the wire they provided. The woofer will have the bom bom sound. What should I do?
Is it the firmware problem?
dreamwalkz
Ouch, seem a bit hard to remove the wooden crate haha.
U manage to change to English ui and install kodi etc ?
Yea, I managed to install Shafa Market app to change language to English, just have to enable 3rd party app installation OK liao.
Tried installing Kodi, no issue too. But not sure what add-ons to put in xD
Sent from Samsung SM-N910G using GAGT
dreamwalkz
Congrats on your hoot. 60 inch ... si bei song.
Realised that you put the subwoofer on the TV console. Actually, the best place to put the subwoofer is on the floor against the wall, if corner, even better.
In that way, when the subwoofer punches out the bass, it'll shake your whole living room.
Hehehe! Gonna try putting it on floor and try it out later!
dreamwalkz
Need some help..
Hmm, I connected my pc and Dvb_t2 box via hdmi to my soundbar as well, no issues with audio to soundbar. For PC, need to set default playback as MI TV.
Haven't tried connecting phone to soundbar yet though.
Woofer cable, I just used the original cable MI provided, whole house shaking when watching movies xD
wlun228
Glad to hear that, do you mind to share the tutorial link on how to install shafa,kodi etc?
Thanks
VodkaPear
Soundbar and Woofer are paired via Bluetooth during TV's 1st time power up.
ya i also paired via bluetooth. but woofer no bom bom sound.
unless i use the woofer cable to connect the soundbar and woofer. :s22:
i1magic
Just add Phoenix & Exodus. If you want, can also add Toggle add-on and YouTube add-on.
VodkaPear
Need some help..
Finally after playing around with the display of the soundbar.
I realised that I should choose 1920 x 1080 / 60p instead of 3820 x 2160 / 30p. (my tv cant support 50p and 60p)
Now the graphic from the soundbar is as swee as i connect my miotv and apple tv directly to the tv.
wlun228
Hi can I check if I buy the mitv3 via daigou how's the warranty work?
No warranty.
Anything happen u need to figure a way to sent back to China for warranty or repair locally at ur own cost.
Daigou just help u to carry it from China to sg, and that's it :)
dreamwalkz
No warranty.
As above, I did a huge upgrade from a classic 40+ inch CRT TV to this 60inch MI TV, would not expect it to last like CRT's 15 year++ xD
VodkaPear
I have trouble connecting my soundbar with woofer using bluetooth but no problem using cable.
Anyone have the link to troubleshoot or know what is the issue? I am using firmware 1.1.94.
Stallone
Actually u guys no include the price of joining as prime member?
That's 99$ right
i1magic
Wah .... good news.
Xiaomi just slash RMB$700 (About SGD$140) for their Mi TVs!
Chiong ah!!
