Xiaomi MiTV2 help
didymus
Btw for those using dvb-t2 box.. issit like an outdoor antenna receiving e signals? Or can just plug into the cable box on e wall to receive HD?
New bto...
UnDeaDAfk
launm88
hi i want to buy the 55" in ezbuy but the one i saw, which is link below do not show the woofer which is normally included? is this the correct link to buy it?
also can i know how much more to factor in to buy. what i saw is 45$ for crate, 3$ for transportation and 10$ for 1 month trial prime. + 7% GST. what else i miss?
$8 for local delivery to your house.....
didymus
Anyone knows where to buy standard size Display Port to HDMI 2.0 adapter?? Wanna connect from my desktop GPU to the xiaomi TV for 4k@60hz.
i1magic
Not sure whether does this support HDMI 2.0.
Item : Display Port (DP) male to HDMI female
Price : About SGD$2.50
Source :
http://www.ebay.com.sg/itm/New-Disp...621582?hash=item25aefd3c4e:g:vtMAAOSwVL1WE8AF
inflames85
After 2 days of meddling around this MiTV3 I've confirmed that the AV jack can't output any sound to the AVR.
Well the other things I've found out about the options for connecting the sound bar to the AVR :
The HDMI #1 is featured with ARC all you need to do is to connect it to the output of your AVR (if your AVR has the HDMI ARC feature) - Problem solved.
But if your AVR hasn't got the HDMI ARC feature, then you need to get a BT Audio Receiver and connect its ouput to the AVR. ( just like mrsun18 the expert mentioned in the earlier posts)
Another option would be getting an adaptor for extracting the audio in to the AVR.
Personally I prefer the 1st option as it is forward compatible to be used in your car perhaps and doesn't waste another HDMI cable.
Did you try using the ARC feature on your mi tv? my avr has arc feature but it doesn't work, any advise?
ralfale
So total cost of buying one 55" TV3 from ezbuy:
Prime membership 9.90
Shipping 2.99
Crate 45
Local SG delivery 8
Xiaomi TV3 903.01 --> According to https://ezbuy.sg/Product/Detail?url=https://detail.tmall.com/item.htm?id=523058040132&src=
GST 63.21 (7% x 903.01)
All in price = SGD 1032
Above URL does not comes with soundbar or woofer etc.
Is my calculation correct?
Still have to add in one DVT2? Which one you guys using? Any recommendations?
