Xiaomi MiTV2 help
produde1999
So total cost of buying one 55" TV3 from ezbuy:
Prime membership 9.90
Shipping 2.99
Crate 45
Local SG delivery 8
Xiaomi TV3 903.01 --> According to https://ezbuy.sg/Product/Detail?url=https://detail.tmall.com/item.htm?id=523058040132&src=
GST 63.21 (7% x 903.01)
All in price = SGD 1032
Above URL does not comes with soundbar or woofer etc.
Is my calculation correct?
Still have to add in one DVT2? Which one you guys using? Any recommendations?
uh oh. U just missed the mitv deal. Mitv 3 55inch was 3499rmb till today.
ToOtWaI
bros who bought the TV3 55" & 65", are you guys able to get it connected to external amp and speakers?
didymus
Since the plug is 2pin plug from china... Which adapter u guys use to plug in power socket ah
maxlovely
i just bought the xiaomi tv 3s 48 inch.
Around $500 bought from qoo10.
is there a thread on xiaomi tv 3s?
rerear
Is there a small 30-32 inch version of MiTV, whatever version, that has refresh rates good enough for it to be used as a PC monitor?
produde1999
Thanks, is this hkc brand reliable? How does it compare to Korean brands like crossover etc?
Sent from OnePlus ONE E1003 using GAGT
yes it's reliable. I'm using the hkc t7000pro bought from tmall.
Doubt has any difference with crossover or benq. It depends more on which model u wan to compare and what usage type u wan.
复制整段信息,打开*********天猫APP*********,即可查看此店铺:【hkc官方旗舰店】(未安装App点这里:http://share.laiwang.com/s/Fv1Qq?tm=db5157 )*********喵口令*********
Note that only buy hkc from tmall, never buy hkc from other places.
You may interested in hkc q320plus model
