Xiaomi MiTV2 help
i1magic
Hi bros, im thinking of using xiaomi 4k tv as replacement for my 27 inch 4k Dell.
I do a lot of browsing, as well as excel spreadsheet work and coding.
Would this be viable? Or will i just get a headache...
Thx!
For mainly monitor usage, you may want to check out Wasabi Mango 4K TV instead.
summersky1986
Bros this is the one right? Works for 3s?
Sent from OnePlus ONE A2003 using GAGT
Lim Swee Tat
Apps from /system/vendor/app and /data/app on mitv3
Hi,
I screwed up my mitv3 after rooting by deleting many of the applications. Can any kind soul who has access to a mitv3, share with me the contents of /system/vendor/app and /data/app?
I have not been able to find any ability to download a copy of the firmware to do a factory restore for the mitv3. Speaking to the chinese support line from xiaomi also hit a deadend because the support staff required that the device be brought to a support center in china to get anything fixed.
Kind souls?
i1magic
Hi,
Kind souls?
You can try this :
Good luck.
By the way, I have tried whatever method that can be found online for the Mi TV 2 55", till today, after >1yr 3mths, my Mi TV is NOT rooted and Playstore not installed.
If you want to play with the Android part, I suggest you get another Android TV box and do whatever you want on it. In this way, if the box is screw, just change the box will do.
ckling
Hi,
Kind souls?
i got mitv3 55...how to get those files?
orangeman
Hi guys, can enlighten me for the xiaomi soundbar, it works with 55"and above tv? For the subwoofer and speaker it works for all models?
i1magic
then what use would the soundbar be?
Because for Mi TV 3S, the soundbar is needed for the TV to work, so just need to get the subwoofer.
If you are referring to the one in the picture, the soundbar should be the one for Mi TV 2/2S. Or you may be able to use it with non Xiaomi Mi TV.
orangeman
You meant for Mi Tv 3? I think I get it.... Mi TV 3 is need soundbar to work, Mi TV 3S the system is back in the tv panel right?
Dearboy87
Im thinking of upgrading my 55inch to 60inch~
any recommendation for who to buy from?
i saw people recommend Mandy from Qoo10~
will she help to check before send?
ckling
Check also no use...who knows what will happen during shipment from China. But the good thing is qoo10 got buyer protection... anything seller will have to replace for you
humanrace
Thinking if getting the 65" 3S flat tv... To ship using prime from ezbuy. The xiaomi official tmall keep on out of stock! Tsk tsk...
i1magic
Aiya .... 55 inch ... go 65 inch lah.
i1magic
From my experience, seller on Qoo10 is not that on the ball with refund and resolving problem with the item. Just make sure you pay by PayPal.
If the seller bo chup you, seek help from PayPal.
