Xiaomi MiTV2 help
jereme310790
I bought mine 65" flat model from Mandy. Finally arrived yesterday! Tested sound and display ok! Wooden crates protect the unit well! Now need to try changing the menu to English and install Youtube app! Anyone try doing that without rooting?
Got my 65inch 3S last week as well! I requested the seller to convert it into English and it came with YouTube and some other commonly used apps like chrome etc and i don't think mine is rooted. However I have 1 problem with chrome, it doesn't seem to have connection so it's not usable at all.
i1magic
Try this.
jtgoh
Thanks! Try the Shafa app and managed to change the interface to English! Now trying to figure how to install Youtube without rooting!
hwaa
can share where u guys get the 65" tv from? got some live pictures to share the poison? :D
jtgoh
bought my 65" Mi 3S from Qoo10 Mandy. Very good service and helpful. Very good value for money for a 65" model. Good display and sound.
summersky1986
From ******* ezbuy, any advice bros?
Sent from OnePlus ONE A2003 using GAGT
i1magic
hey guys,
i just bought the MiTV2 shipped from china. so far the display is awesome but looks a little less vibrant than the 4k displays from samsung.
so here comes the problem. the screws for to wall mount are impossible to find. the closest i've gotten was one with the same diameter but the pitch between the threads was off. does anyone know which screws are suitable for the TV?
other than that. great TV at an awesome price.
Dear TS, how's your Mi TV2 so far? Or you changed already?
jtgoh
Tried download the youtube apk, this time, they ask for associating googles services. Tried installing the googles services apk too. Youtube can installed but can't run.
i1magic
Ok. Before we go on, let me highlight few things.
1. I did what I did 1yr+ ago. It was trial and error, so I couldn't remember exactly what I did.
2. The seller which I bought the Mi TV 2 55" from already install YouTube for me when I got the TV. But I tried many methods and still couldn't get PlayStore to work. But I can watch YouTube on it.
3. If you really dare to explore further, do take note that make sure you learn how to reset your TV.
Ok, if you understand all the above, you may try :
http://www.majordroid.com/how-to-install-the-google-play-store-on-the-xiaomi-mi-box-mini/
Or this ..
Good luck.
PS : At your own risk
hwaa
or try mirror from phone if it works den no need worry abt screwing the tv up..
