Xiaomi Redmi 3S
sillyb0y
use the beta mi flash version (search on miui forum).
the steps to flash can be found on mi max thread.
expert, should i dl which ROM? i flashed to Global stable ROM but its locked my device. If i flash to china ROM, would i able to get english?
JivBunny
Gotten the Redmi 3s at the race course road famous exporter shop again.
India export model with fingerprint scanner at $165. Gold color. Global ROM installed.
Truly if not bcos of my dad preferring a 5inch, I would say the RMN3 is a better deal now at $225. Which i bought it at $240 for my mum around a month plus back.
otacon
Wah, I live there leh, din know got famous exporter. Their price good? Care to share the shop name?
Sent from iPhone 6S using GAGT
bundy
yea. dun mind the shop name for share share
JivBunny
Naranjan.
But I gotta warn pple going there to buy. Don't expect service. You pay then you can test the phone. Make sure u bring extra sim and test on the spot after buying and confirm 7 days 1:1 exchange before you pay. Make sure u ask them write on the receipt. They can be chow kuan one.
They mostly sell export phones. Most brands and most models are all export models.
I also knew about this shop few years back from the forum and have bought 3-4 phones so far.
So far this year I have bought 2 RMN3 Pro and 1 RM3S from them. Touch wood so far so good.
Some people feel that the extra $50 to get local Redmi set with warranty is worth it, which I don't deny. But I think I can stomach the risk
dnlei123
Hi, i see you got yourself a RM3S.
Does this support dual SIM standby on 4G/3G simultaneously? Or will one SIM be on 2G if another is already on 4G/3G? Thanks to help evaluate :)
Devilsire
mine RM3S 16gb with fingerprint (china set) just 4G/3G + 2G.
Gotten mine $99 few days ago, didnt play with it much but here's a short review imho:
+ 5" handy size, slightly fatter than Max
+ Support QC 2.0/3.0 unofficially, though not at optimal speed (Tested getting ~1.7A 7.5V )
+ Decent camera in daylight, slight lag compared to other models ( Mi4i > Max/RMN3 > RM3S )
+ Decent battery life
+ Fingerprint sensor (similar to RMN3 / Max)
+ IR (similar to RMN3 / Max)
- No AC WIFI i.e 5Ghz
- No global MIUI 8 beta release as of yet ( = no dual whatsapp etc )
- No touch screen to wake feature
- Non full HD display @ 720p, though not that it matters much on a 5" screen
Basically its a slightly toned down + mini RMN3, at a cheaper price of course. If one prefers a small screen & using it mainly for basic calls, texts & web surfing, at <$160, sure why not. For multimedia/gaming, would definitely recommend Max or RMN3 instead.
swathe
What case to buy for Redmi 3S? Does the Redmi 3 casing fit?
swathe
If mine is the version without fingerprint, can the redmi 3 one fit?
vibranze
What is the diff between Redmi 3S Pro and Redmi 3S Prime? Are they the same?
Is the spec listed in Lazada accurate?
Just want to make sure before buying in order to avoid getting wrong model.
Thank you.
amazingone
Thank you.
3S Pro and 3S Prime are very similar devices, both featuring the same specs but 3S Pro is the China variant while 3S Prime is thr Indian variant, which means the Prime will be preloaded with a Global ROM with Google Play.
Sent from Sumire using GAGT
vibranze
Thanks bro.
So, both series wont have any issue with SG LTE and it supports all the bands we have right?
Is it safe and the cheapest to purchase from Lazada? Any particular recommended and to-avoid seller? Any promo code that I can use?
I am not sure how the 720p screen fare. Currently I am using P9 but prefer real 5" phone so would like to try 3S Pro.
Thank you.
amazingone
Thanks bro.
Thank you.
Yeah both can support SG LTE network.
Should be safe on Lazada, as they offer buyer protection. Not too sure on reliability of sellers on Lazada though, but for promo code if you got SCB card then there's an attractive promo code for use. Do remember to use Shopback too~
amazingone
