Xiaomi Redmi 4A
hehuafa
Its actually a data saving feature. It restrict downloads on data if the apps size is too huge. The setting can be change to un restricted. So no such stoppages or warning when downloading with 4G network when there are no wifi hotspot around.
Can check with bros here how do I enable to download app from Google play store using my data plan? Seems like it keep prompting me the app size is too large and require WiFi to download…
Kiwi8
Deluxe Member
How much u got it for ?
Saw qq10 time sale unbelievable 99$ n with 6month shop warranty included.
If the phone is good, at 99$ can get one as spare phone n play about.
$109. :o
localITguy
Suspended
Guys. If you are having issues receiving notifications from certain apps,(eg: Pushbullet)
Disable the permissions manager completely and that will resolve all notifications issues
Enable developer mode> additional settings>
Developer options>enable>
Scroll down and turn off MIUI optimization
Reboot device
Open security app>permissions>Gear icon>disable the first option.
The permissions manager is junk anyway..
eddy0505
interested in buying this. any user can help share a short review or share the Screen on time (SOT) ? TIA!
blengend
Does Redmi 4A have the same connectivity problem with Redmi 3s?
The stuck at 2G problem
hwbest
global rom is not yet available. is the phone usable in singapore? can google?
Kiwi8
Deluxe Member
Yes, usable. Just follow the instructions that are available online to download the Google Installer apk and it will automatically install all necessary components for Google Play Store.
hwbest
ok thanks kiwi8, this is helpful! but would the google pack be too bloated for the ram and slow down the phone? quite fearful because the ram is only 2gb..
Kiwi8
Deluxe Member
My usage pattern is just playing Pokemon Go, so I can't vouch for the full capabilities of this phone as a main workhorse phone.
If u want to use a phone as your main phone, perhaps can consider getting the Redmi 4 Prime? :o
hwbest
ok sure! thanks kiwi8, shall check out the redmi 4 prime :)
Kiwi8
Deluxe Member
Redmi 4 Prime is 3GB RAM, 32GB phone storage.
Your concern with the Redmi 4A might be valid, cos even before I start the game, the remaining RAM is already just 1GB. So it indeed might be a concern if it's gonna be your main phone to run the usual stuff like WhatsApp, Twitter, Telegram, Facebook, etc etc.
hwbest
ok, shall keep this in mind. will certainly need those apps you mentioned!
juuzbe
Go to Shopee, got one shop JTBC Group selling $99 for 1 year warranty. $89 if 2 weeks one-to-one. Self collect at FE shopping centre.
Wonder does the phone from this shop comes with google playstore? anyone bought from them before?
Googleplex
Can anyone with this phone test dual sim? Is it 4G+3G capable like 4 prime or only 4G+2G like 3s?
