Xiaomi Redmi Note 13 series
caterham7
How does Note 13 series versus Poco 6 series rank in terms of camera
Especially something like 13 pro+ vs X6 pro (K70E) since they should be both ~$450
CPU, screen, storage, battery, charging all those are fairly simple to compare 1 for 1
Avoid both if camera is a consideration
Pixel 6a will do better
carboy00
I'm probably wrong since i'm anecdotally guesstimating from various reviews online. It seems Redmi Note 13 Pro and Pro+ are using the same camera and the difference are cpu, batt/charging & IP rating
And K70E vs K70
Review/ First Look
, the cameras aren't too much difference. Then there is this
K70 vs K70 Pro
said K70 Pro isn't much better other than on paper spec
That would weirdly mean RN 13 Pro+ (same camera as RN 13 Pro) have better camera capability as all three K70s
In the Poco context, X6 having better camera than X6 pro, F6 , F6 pro
yup you could be right but there are instances where Poco rebrand where some specs were changed, sometimes on camera side. Let's see how the X6 series turn out, supposedly 64MP main cam both on X6 Pro and X6.
Read HWZ Forum Rules on Poco F5 Pro
Jurong640
Xiaomi Redmi Note 13 Pro+ hands-on review​
pilico
I bought the note 12 pro plus previously from shoppe using china rom when it came so i unlocked bootloader and flash global rom + magisk and all works fine
May i know if google wallet/nfc are working fine?
SuperDecker
Kenna floored when I saw the pricing. Redmi Note 13 Pro Plus 8/256 priced at $489 before vouchers/discount. X6 Pro at $419 with faster chip, 5x ram and UFS4.0
Jurong640
Just passed by xiaomi store, they just installed the Note 13 series including the Pro +. The curve looks cool. Didn't get to play the phone as its not charged up. Tmr you all can try the phone in stores.
The back panel looks nice, not sure how the phone will perform
DesilDesil
How is 13 Pro $419 when the rebadged X6 is like 20% cheaper
Even X6 Pro, Redmi K70E rebadged is same $419 but got $15 voucher bringing it down to $404
Jurong640
i remembered a lot of reviewers say Poco has tons of ads. not sure how many ads does xiaomi note 13 has. The ads subsidies the phone price
caterham7
both have a lot of ads, but can be turned off quite easily
https://www.androidauthority.com/remove-ads-xiaomi-miui-1019139/
the main factor for price difference between poco and redmi is that poco sells direct to consumer, cutting out the middle-man, a.k.a. local distributor
can save quite a lot of overhead costs there
chris1987
Does the phone comes with google installed?
Looking to get one for my parents.
ZrE0_Cha0s
if u buy from this Xiaomi Online Store Global - Singapore den yes google is installed.
tian_yibang
Think XM hv rollout/launch too many new fones at same time in order to generate pre-CNY sales or gain early market
so much so that its literally eating into each other sales
Anyway
this guy has made it clear in the video title
But moi find even the "early bird" price still ex
will wait till price drop then consider buying
caterham7
wwh5210
The specs of POCO X6 and Redmi Note 13 Pro are almost identical (except the main camera) but the prices are $339 vs $419. Why is that so?
Is xiaomi comparable to Samsung A series?
I downgraded from flagship of various brands to Samsung A3x but it's too laggy for me, A5x is ok thou. Not sure if want to switch to poco/xiao mi next
