Xiaomi Redmi Note 2
clay9477
Actually if wait until Dec, really is "old liao". Mi4c announcing soon. And by the time we get mi4c, can probably get mi5 already haha.
If want, just buy. Don't wait. It's never gone end. New phone getting released every now and then.
We won't be getting Mi4C for sure. It's strictly for china. Also Xiaomi phones in general reach our shores always months later from first release due to logistics process....so i don't see anything wrong with the wait.
Anyway if anyone want to buy can consider via 65daigou. Quite cheap to buy the 32GB, total cost plus shipping less than $260. Worth it for double the storage.
Eidekos
Hi,
whats the difference between the prime and not-prime version? adix selling 280 for the prime. anywhere can get cheap? thanks
Audiology93
Have to import 1 :(
Hi,
2.0 vs 2.2ghz. 16 vs 32gb. Buy from xiaomi china.
Eidekos
Thanks! Btw got the redmi note 2 from adix. Everything was working from app installation to updates.
This morning my play store got error. "check connection and try again"
need help. do i need to re install and factory reset again?
Sent from Xiaomi REDMI NOTE 2 using GAGT
k0g3pAn
Wooo my prime edition is here!
Sent from Xiaomi 2014817 using GAGT
laironpark
Mobile Bee is selling Redmi Note 2 @ Lazada for $205.
Thinking of hooting one. Anyone here has any problem dealing with Mobile Bee?
kazuki666
any local sellers with scr protectors, casing and extra battery?
If u are not in hurry for time, can try taobao. I ordered tempered glass screen protector and silicon back casing for S$5 before shipping. I think even after shipping should be still cheaper than what u can find locally.
Eidekos
mines for sale. just 2 days. android for me. sms 97116345
mehmeh91
Finally collected my set from Mobilebee( bought it on qoo10 with coupons/discount). The set was the 799 rmb version without the FDD LTE. However , it worked with my singtel 4g and it is installed with playstore too.The set took quite a long time to start up for the first time .
May i ask has anyone updated to miui 7 or upgrade the firmware ? Does it removes the playstore? Thanks in advance :s12::s13::s12::s13:
