Xiaomi Redmi Note 2
laironpark
Found another global rom MIUI V7.0.8: LINK
Takes a long time to download. Google Play is pre-installed.
Great standby time - left it overnight with wifi off @ 100% battery charged and this morning, it is still 100%.
My initial impression is that global rom do not drain the battery as much as chinese rom.
So far so good, will use it for another couple of days to gauge performance and stability. :)
PS: Root will be lost and recovery reverts to stock Mi Recovery.
tonyep
Ordered 2 sets during the 2nd wave of preorder, it's ready to be collected @popstation today.
lockks
No big difference...removable battery for budget phone is preferred.
Waiting for xiaomi to shift to oled screens...
clay9477
MIUI V7 5.11.5 - developer rom, still beta with couple of bugs. Decide to abandon it.
7.0.8.0 had the most bugs thus causing the delay of the global rom. Good luck with that.
chomechome
just got my phone from xiaomi sg.
can i ask is there anyway to see the whatsapp icon in the phone contact? like other Samsung phone? now i cant see the icons not sure why.
thanks
lockks
Not very stable. After browsing for a while all the apps will suddenly close.
Shutterx
thanks
in my contact, can see whatsapp viber wechat icon [to msg or internet call] as long the other person has the same apps too.
didnt happen to me. so far is smooth
aogiliu
you off wifi, your battery sure got maintain 100%. if you on wifi, some Redmi note2 can drop 10%-30% battery over the night. I flash Poland ROM, with wifi on, 9 hours battery still remains 100%. haha
Sent from Xiaomi REDMI NOTE 2 using GAGT
chomechome
Do u mean you can see all the icons in a single entry in phone contact? Which rom version are you using?
cscs3
It cannot read from your contract list by default. This has been a long issue with Xiaomi/Redmi series.
