Xiaomi Redmi Note 2
cscs3
budget phone don't "hiam" so much lol...
It depend on how you define dudget phone. To some people, $200 for a phone is consider as expensive.
At least, I do not think Xiaomi defined Redmi series as low end/budget phone.
clay9477
The memory management for this phone sucks. Tried out a display set at challenger. With only the stock apps, I could only free 650mb out of 2gb memory.
Go to updater. Click the 3 dots. Boot to recovery mode. When in recovery mode, select wipe option. Then go wipe cache only, once done, reboot. Confirm 1GB ram free space.
ghgan1
Nope, cannot applied coupon code or dbs credit card discount, last time bought during 11/11 with discount n shopback but shipped the wrong phone, kena refund.
Can use coupon code this time? Last time 11/11 price is higher but after discount n shopback I pay only $185
whoooo
mine this below, cannot use 1 set as benchmark lei bro , esp when that set is demo set as pp might have install and uninstall app etc
Computeron
any ones how to change the texts size? everything look so big... i changed it under settings... still as big. like for old ppl
clay9477
65daigou first parcel free 500g from today till 14, very good deal if you want to buy Xiaomi Backcover, plus now got 10 yuan discount means cover cost 19 yuan only but need buy heat insulation tape! :s13:
Kennedy
have the error "unfortunately google play services has stopped" after power on. I had cleared the cache and data of google play store. how to fix it ?
luei74
My lazada note2 came with preinstall google play... With V6.7.2.0 (China ROM)...try to upgrade to the latest global V7.0.12 but failed...only manage to change to the beta global V5.11.12
Currently the phone receiving the OTA V5.12...not sure if it's will eventually updated to the latest global ROM??
Sent from Xiaomi REDMI NOTE 2 using GAGT
AMD1800
Redmi Note2: "Unfortunately, Whatsapp has stopped"
Hi,
Was sending a mp4 video, 29sec long, 6.5MB size... then receive this message "Unfortunately, Whatsapp has stopped".
Then tried another mp4 video 4minutes long, 4MB size... successfully sent.
Is there any setting in Note2 to resolve this?
Thank you.
luei74
kazuki666
Hi,
Thank you.
Do you have problems downloading files of similar size? I remember there is some setting in the security about download limits
