Xiaomi Redmi Note 2
luei74
android17
Hi guys, I just ordered Redmi Note 2 from xiaomi. Just wondering if the default rom of the phone is good enough to use, or should i just install a custom rom right out of the box?
luei74
Better to use the global stable V7.0.12.....can check if your set already flashed with this rom, if not recommend to flash with this rom.
kazuki666
Hi guys. I am having some problems connecting to whatsapp on my Redmi Note2 Prime after i click on the Cleaner widget. It will totally exit completely until that my whatsapp stay "quiet" until i open whatsapp then realise there were messages which was received but never pop up in the notification.
I did configure my whatsapp in the Security > Permissions > Autostart already. I also configured Setting > Notifications > Manage notifications. But both methods don't solve the problem... :(
jedi5diah
seriously i never use the cleaner...it basically clear cache for every single app, for apps that use cache often like gallery will "suffer" to recache when you use them again...
aireth
Anyone got issue pairing with bluetooth device? Dunno why my RMN2 can't find my sony bt earphones but my LG picked it up straight away.
hyper_megaman
go to home screen
press bottom left menu to open list of active apps
scroll to whatsapp icon, and drag it downwards. you will see a red (x) appear on the top of the icon.
done!
it's nothing to do with clearing of cache, it's that your unused apps are being terminated. doing the above locks the whatsapp in and prevents it from being terminated by these cleaning actions
Techno Pride
Is this a 4g+2g phone, meaning as long as one sim is sitting on 4g, the other will be forced into 2g?
tanchoo1
Yes. As long as one SIM is using 3G or 4G, the other will be forced to use 2G.
You could setup either the SIM 1 slot or the SIM 2 slot to use 3G / 4G; there is no need to swap the SIM cards around.
Techno Pride
Yep I already have a Redmi 2, which is 4g+2g. Was hoping the Redmi Note 2 would have 4g+4g.
Game over in Apr 2017, when telcos shut off the 2G network..
kababoom
Thinking of hooting this phone any custom rom to recommend MIUI not to my taste also are they any backlight for the back keys etc?
android17
anyone knows if there's any solution to this whatsapp issue?
When i receive 1 message, i can read it from notification bar. However when there's multiple messages from the same contact, it will list it as "Contact name- 4 messages" and wont let me read those messages from notification bar.
Is this due to MIUI or due to the new Android OS?
