Xiaomi Redmi Note 2
kazuki666
Ask u all. If next time I buy a newer Xiaomi phone, say Mi5 or Redmi Note 4. Is it possible for me to restore data i backed up from my Redmi Note 2?
clay9477
Not for apps. Only msg, notes and etc will work. Broswer may fail due to incompatible versions.
kazuki666
hmm... How about say from Redmi Note 2 to Redmi Note 4?
If the backup/restore doesn't work across Mi and Redmi, then abit sian le...
kazuki666
I notice that my Redmi Note 2 Prime is getting the "connection issue" with Pebble watch again. It shows connected on the watch and phone, but notifications are not bumping up on the phone... Tried unpairing the watch and the phone, and pair again, no use too. The Pebble app is locked, so it cannot be the app is in sleep mode.
I am not sure if its only with Xiaomi phones...
Bryson
What firmware you using? I'm on dev rom and I have no connection issues..
Sent from NVIDIA SHIELD TABLET K1 using GAGT
i1magic
How is the ram holding up for most of you? Is 2GB enough? I am contemplating to get Redmi Note 3 because it got 3GB ram. But I seriously not used to NOT having microSD card slot.
Just Me
Unless it's an iphone :)
caterham7
fyi, rmn3 snapdragon 650 version allows 1 sim card slot to be used as a micro-sd slot
Backlash
Been using it for about 2 weeks. For a daily driver (non-gaming), it is more than sufficient. Text, Facebook, Surfing and You-tubing.
kazuki666
What is your regular usage on? I played some games like Naruto and Dragonball, normal facebook and google. So far no problem. I think many times most of us get very highend phones, but don't really get to utilise its max functions also lor...
Anything_Whatever
There are times when a particular app fails you, make you like wanna smash the phone....
I use Lenovo PHAB plus and the google map navigator will always fail me when I am driving... The phablet will get very hot and the app will hang. I always have to find a place to stop the car to shutdown and restart the phone.:(
Hope this wil not happen to your XM phone.
kweeli
May I know how long to received phone if order from xiaomi website.
I order mine last thrusday n select pick up at popstation. But till today, still no information abt items ready to pick up.
