luei74
- Aug 5, 2001
Very cheap...less than $150...How much you sold your note 2 for?
Just sold wife's RN3-X10 (32gb) $180, with 20+ low ballers, only 2 keen buyers. Upgrade to RN3- SD/32g for $195. Mum's RN2 16gb,can sell for $130, not bad already. Myself MiMax.Sad. I was trying to sell it at $150. Seems like not possible...
Going to pm you regarding the battery.
I'm on miui 8. Not much difference in terms of performance other than the dual apps which is very useful.Anyone flashed this phone to MIUI8 already? Can share any significant pros and cons comparing to MIUI7?
Battery still cui.This redmi note 2 is it having battery drain issue in miui8? Or best to stay at miui 7.1.1.
Did any of you have problem with Redmi Note 2 battery bulging up? After using this phone for around 7-8 months, I noticed the phone's screen curving up and initially I thought is the tampered screen protector coming off so I just keep pressing the screen back. After a while again, I got fed up and took nearer look then realise it's bulging from inside. Open up the back cover and saw the battery bloated up like about 2mm. Immediately stopped using and bought a replacement battery from tmall, but sadly Xiaomi never released original before, so I had to make do with whichever seller's reviews is more legitimate.
Last night I notice a slight bulge on my phone (new battery) AGAIN... Opened up, same thing but just not as bloated yet. So I did some Google on Chinese websites and found out it's actually not an uncommon issue. One of the thread actually teach to poke the bloated area with a needle. It's unsafe I know, so I took my precautions. I decided to try on the original battery. One prick and can hear a whizz of air coming out. And the bulge is really gone! So now I put the original battery back into the phone. Haha so I thought share some inputs I experimented.![]()
But I guess overheating may be a problem for long, so just matter when I get a new phone...
Sent from Xiaomi REDMI NOTE 2 using GAGT
Your sets also same problem as in the battery bloated up? Btw, the battery sold at that SLS shop also not original for Redmi Note 2 right? This model has to be the most short shelf life form Xiaomi...You can get the battery from Sim Lim square level 2. Cannot remember the shop name. Is behind row one. BM45 is the model, around S$15. Xiaomi battery not so realible. My Redmi 1, Mi4i and Redmi note 2 all has this problem (local set).
If yours is same situation as my battery. Is the outer sticker peeling off from the battery pack already? If same, you will be able to peek in and see the bulge. Use a needle to poke at this bulge. You will hear a hissing sound as if gas leaking. But PLEASE do this with care since it's battery and there are chemical inside it.hi there, i have the same prob recently. so bo bian have to buy another batt from qoo10.
may i know exactly where on the bloated battery do i poke a hole? thks.
