Xiaomi Redmi Note 3
eekee
Have you done the CIT test? If not you can try
1)Tapping "Kernel Version" under About Phone until you launch CIT
2)Go to no.12 Light Sensor and see the value for "LightSensor" eg. 80.0lux. Then cover the black bar on top of your phone and see if the value decreases. If the value doesn't change then something might be wrong with the hardware inside.
I used he app Android tester...there is a change in Lux when sensor is covered. Somehow, I just don't see the screen brightness dimming when the sensor is covered. Does you screen dims when the sensor is covered?
Nakedtoes
My light sensor is turn negative value under hot sun.. But now work normally liaoz after take out and put back casing.
Audiology93
I don't usually use auto brightness but just tested and mine is working. I used a flashlight and shine it directly on the light sensor. The screen did become brighter after 2-3 seconds. After i remove the flashlight, the brightness lowered after 2-3 seconds.
seph
Hi, checking if M1 users can connect to 4G network on this phone and on what firmware version? I can't get 4G after update to China developer rom.
eekee
Yes, mine reacts to the torchlight method.
kelvinti
Finally, found a TPU clear case at one of the shops at slq after 1 hour of searching. :)
Everywhere is no stock for transparent case.
