Xiaomi Redmi Note 3
8-lane
Gold 小貓 & Gold 小米 :s13:
Both can insert SIM card anot?
kelvinti
OK. Spend $2 to cut into nano sim for sim2.
Both sim1 and 2 are working perfectly :)
So far so good. I'm really amazed by the performance of this Note 3.
The ui is smooth as silk..
Nakedtoes
Yes superb value phone.. If same spec the new mi max also should be quite good.
Grandturismo
Using this case u got try under hot sun or bright sun the auto brightness work?? mine like very funny in bright hot sun light the screen dimmed to cant see.... then i go hardware test.... and yes during sun light the reading is negative lux..... then i remove the case to try the phone reading is correct under sun light... and shade also.... then i put back the Ipaky case it work normal liaoz.... really puzzling me..
for those want to check hardware dial *#*#64663#*#*
I not using auto-brightness function..maybe will try out :D
hyper_megaman
btw u all got lobang for authentic local powerbank? looking at xiaomi 20k mah powerbank, but website keep having no stock
challenger starhub all those got sell?
kelvinti
Hmmm.. The Notification Bar damn small. Anyway to make it bigger.....
Marbok_Tan
help! my pc still doesn't detect my redmi note 3. anyone knows why?? but it can detect other phones samsung and sony
tried connecting my redmi note 3 to my office pc. it works. only my home pc cannot detect the redmi note 3. the phone is charging though
kweeli
Those looking for the xiaomi redmi 3 note, bedok starhub have both gold n silver as of yesterday. $299 for the phone.
eekee
Any idea where is the light sensor? Automatic light sensor doesn't seems to be working....covered the top portion of the phone, the screen didn't dim.
eekee
Found where the senor is and it is working. Just that the Auto brightness doesn't seems to be working...screen doesn't dim when senor is covered.
Audiology93
Have you done the CIT test? If not you can try
1)Tapping "Kernel Version" under About Phone until you launch CIT
2)Go to no.12 Light Sensor and see the value for "LightSensor" eg. 80.0lux. Then cover the black bar on top of your phone and see if the value decreases. If the value doesn't change then something might be wrong with the hardware inside.
