Xiaomi Redmi Note 3
ZhuTou!
Is there a way to selectively restrict background data for apps?
Like restrict but still get my Line, Whatsapp, Instagram notifications
Cannot
When u get notification, it is using push notification
If u disable background data, how is the app going to use push notification?
ZhuTou!
Where can I buy screen protector and have someone apply for me? I suck at applying screen protectors
Buy tempered glass one, very easy to apply urself
Just align properly, use one finger press the middle of the screen and let the glass stick by itself
Then use the small supplied cloth clean the glass
No bubbles one
It is alot easier than the normal plastic screen protector
Emospence
Cannot
That's why I asking if can allow some apps and restrict some mah.
Devilsire
Several types of those ultraslim soft cases...
I've gotten 3 total.
IMO Best quality is from carousell, $8, buttons good to press, individual cutouts for the fingersensor & camera, with protrusion to protect the cam lens as well, and very thin (almost naked feel).
The other 2 i gotten from shop & qoo10, buttons harder to press, whole piece cutout at the back, no protrusion and slightly thicker etc
FinalTidus
Nakedtoes
The tpu case got few models in the market.. Got one even has ports cover.. I brining in 1 pc to try.. So far the best tpu case are black color S type patten behind one.. Color will not turn yellowish, Quality is good, cut out is perfect, button press got protrusion and offer best protection.
nomoney25
just checked the CEE 2016 brochures from challengers that XMN3 is selling at $299. For those who cant wait till 31 may flash sale. Challengers should be selling the official local set
Kitaro9202
Not bad close to a day left 40% sot around 2hr+
Sent from Xiaomi REDMI NOTE 3 using GAGT
i1magic
Just try it again. If cannot, just take out slowly, wash it and try again. One way is to spray water on your screen, put the screen protector on .... adjust it properly liao and push out all the water with credit card.
Nakedtoes
Yes plastic SP can be rewash and reapply... i am quite an expert in pasting SP and i always ensure mine not a single speck of dust one... LOL
It is always easier to paste tempered glass protector but glass protector u cannot have more repaste cause the adhesive might spoil after u peel off and glass edge might chipped off. Some glass protector u place on phone will glide one... then u slowly align then press use finger on the center then it auto paste to sides... for plastic protector u can re peel and use again and again.... mine method is seat on higher ground... prepare tapes.. one folded on end to remove the protector film. one pc of tape to remove dust.. place tempered glass from top to slowly down to screen using the cut holes to align.. slowly place down protector.. quite easy..before u totally force whole pc down check got dust... if got dust slowly peel up the protector using finger nail and use tape to remove lor either under the protector or on the screen. Of cos before paste use tape to clean the screen off dust, on the aircon and no fan blowing at u (thus no dust).
Actually before paste u put the protector above the screen to judge how smaller the protector is.. this is to balanced the side... the most difficult tempered glass i paste is for this sharp phone 402sh cause the edge of screen is chamfered 45C.. i manage to find one exact fit one.. and u need to paste swee swee else very ugly.
Emospence
Oh sorry. The Clasy case doesn't have protrusion too but because it is so much softer and thinner, pressing the buttons is much more easier and super responsive likes there isn't anything there at all. :)
Is it? The picture look like have lei. Is it a soft or hard case ah?
Hakaima
Unknown number's SMS can wah! :s22:
Can dial and create new contact from unknown number's SMS wah!
The same should apply to WhatsApp...:s8:
I was referring to numbers inside the message it self. Eg. Somebody send a phone number or numbers in a message, other brands will pick out the no. as a hyperlink to make calls or save no.
