Xiaomi Redmi Note 3
Kitaro9202
I try liao cannot
I install ifont but cannot set the font
No option to set unless root
Need root leh try before all my hp use before 1 month i root liao
Now this xiaomi using over 1 month haven't go root
Emospence
So far the gallery and contacts apps aren't the best.. No option to move pictures via gallery and the import contacts doesn't work too well, imported contacts only show if I allow show SIM contacts, in which case it shows all the contacts >.>
Can I turn silent mode and have no vibration ah?
amazingone
Turn on 'Silent' and turn off 'Vibrate' at the notification centre
Sent from my Rice phone using GAGT
ceestudent
got pic?? i see isst same as the $2 one from QOO
I also buy the cheap one from qoo-taozi, agree with you tht it doesn't have protrusion at the power and volume button. Difficult to press.
To kelvinti, is yours also the same?
kelvinti
Yes, my case doesn't have protrusion. Damn difficult to press the buttons! :vijayadmin:
My gf one has protrusion and it is really easy to press the buttons, and the case is thinner too. The brand is Clasy! :s22:
I will change to Clasy soon!
Hakaima
I just realized that my whatsapp and sms doesn't pick out numbers in the messages to quick dial or save as contacts. Is this due to miui or is there some settinngs that i need to enable.
All other phones seem to have this feature as default
Sent from Xiaomi REDMI NOTE 3 using GAGT
kelvinti
Unknown number's SMS can wah! :s22:
Can dial and create new contact from unknown number's SMS wah!
The same should apply to WhatsApp...:s8:
ceestudent
Where do you buy this case? From carousell?
ceestudent
I also found it on carousell from $8. It is more expensive than normal TPU from qoo.
Will try to go down to mobile square later. Thanks.
RSKeisuke
Hey guys, does your phone heat up quite a bit when being charged? My mum's complaining about it. Or is it normal?
kelvinti
Oh sorry. The Clasy case doesn't have protrusion too but because it is so much softer and thinner, pressing the buttons is much more easier and super responsive likes there isn't anything there at all. :)
kelvinti
Bro,
Where you stay ahh?
Thought of asking you to buy one for me too, then I pick it up from you later.
Me lazy to go to far East... Kekeke..
Me around Aljunied MRT area...
Emospence
Is there a way to selectively restrict background data for apps?
Like restrict but still get my Line, Whatsapp, Instagram notifications
