Xiaomi Redmi Note 3
kelvinti
Interesting... :s8:
1) The Low Light Camera Quality is Poor
-In Kenzo, Samsung Isocell S5K3P3 sensor is used, this sensor is quite good and is used in many Samsung devices. I can assure you that it is an optimization/software issue. With every update, the camera is getting better. To receive the latest updates, you can switch to the developer ROM.
xiaoyuer89
hi all, how do you guys transfer all your apps from your previous android phone to the mi note 3? wasnt using a MI phone previously.
thanks
ZhuTou!
no shorter way? cant seem to find the google restore with mi note 3... was able to do that with my zenfone 2
I think playstore got a setting to auto reinstall back all the apps
Other methods i duno liao
i1magic
I managed to get my hands on the Mi Max today.
Seriously, it doesn't feel that big and the weight feels similar to Redmi Note 3. Plus it got 4,850mAh battery!! And it is running Android 6.0.1.
Hope that Xiaomi will release Android 6.0.1 for Redmi Note 3 soon. It would make the battery life for Redmi Note 3 even better.
ZhuTou!
The big battery cannot get 10 hrs SOT hor
Based on user feedback in their thread
Its a good phone tho :o
kelvinti
This morning, the fingerprints sensor gone has crazy a bit... :s22:
Put my finger to unlock.
The screen unlocked but it locked back straight away again..
Repeated many time, same issue.
Reboot phone. Tried again. Okay for the first few time but the problem returned after a while...:o
At the end, removed my current fingerprints profiles and reassigned new fingerprints again. So far so good. Fingers cross! :s8:
Seehuatsee
Only happens if you are using those flip cover
Sent from Xiaomi BLUEMI NOTE 3 using GAGT
ZhuTou!
I use fingerprint to lock app only
My phone never lock one :s13:
