Xiaomi Redmi Note 3
Kitaro9202
Testing low light
You guys judge it
Sent from Xiaomi REDMI NOTE 3 using GAGT
ZhuTou!
My mi remote app doesn't seems to be working. Unable to turn on my during setup.
I'm able to use a 3rd party remote app on my redmi note 3.
Anyone successfully setup their mi remote app?
I can turn on my tv ah
The app will ask u to do some configuration by press and hold the button many times
Configure until the app say ok then can liao
Need to choose the correct brand also
kopi22
Can yours work with starhub set top box? I can't seems to configure it using the MI Remote. I tried using the Peel app also not smooth sailing with the setup.
eekee
During configuration how long you hold the button before letting go?
garychengjw
Was there today. They also have mi5. When I ask, they say is SHOP WARRANTY. Don't say I never say ah bro GARY or gadgetsgeek
You sure they got mi5? Other booth?
Everyone know I gadgetsgeek, can openly say la. :s22:
ZhuTou!
hdr need to have stable hand leh
this one low light shot:s22:
Can one
U tab screen to focus first
After focus then snap it
There are many ways for u to snap pic ma
Fingerprint, volume button, tab focus position 2nd time, tab the bottom screen snap button
See which position suits ur hand to prevent the shake lor
ZhuTou!
Example when i setup my tv
The first instruction is hold button till ur tv turns on
So i hold till my tv turns on then release lor
In some cases u hold the button for quite long and nothing happen, the mi remote will ask u things like, does it work?
When u see the msg u can release the hold liao and choose not working
Then the app will proceed to next step to configure
kelvinti
Note 3 look amazing for sure especially its golden back. And just right with the size.
Yeah! I must agree that Note 3 size, design and feel is just spots on.
It has been the most comfortable handset I have ever hold in hand. Just the right design and size.
Anyway, after 20 hours with my Pro 2, I can't take the lag. Coming back to Redmi Note 3 now. Lol... :)
ZhuTou!
:s13::s13:
