Xiaomi Redmi Note 3
Shadow79
any of you guys get problems with 5GHz wireless?
i can't connect to my routers' 5GHz networks at all. it will keep giving authentication problems
this is across 2 rmn3 phones. with 7.3.2.0 and 7.3.5.0
my rmn2 works fine though
You need to set to lower channels. 36 to 48. RN3 don't work well with higher channels for 5Ghz
xiaoyuer89
Very rare now....almost every well-known or mainstream retailers are out of stock! :o
You may find it in those HDB shops if you are lucky enough! :s22:
Am finding it as well. Wonder if xiaomi will do restocking for gold color...
hyper_megaman
i live in a HDB which has a lot of wifi lei.. my house alone has 3 routers lol
there's over 20 wifi networks that can be detected at any point of time from my room
don't have the luxury of selecting a lower channel lol.
this has to be fixed la
kelvinti
KNN.. Again... :(:vijayadmin:
Just reached home and sit right in front of my 5ghz router also cannot auto connect.
Instead it connected to my weak 2.4ghz from the router far away in my room. :(
I will lower the channel later to see it fixes the issue.
Just Me
KNN.. Again...
It won't work with channels >48. Tried at my friend's house using ac88u. Can detect but won't connect when it's set to ch157. But 36 no problem.
Sent from Xiaomi REDMI NOTE 3 using GAGT
batniss
Using 5GHz, no issues connecting to it as long in range
On ac68u
I am on channel 157/80. Configured as auto though.
batniss
kelvinti
Ok.
Just changed my Channel to 36 on my 5ghz router.
Channel 48 indeed doesn't work!
Will report back the result later.
kelvinti
Hookay!
Walk to and from my room to living hall and via verse 5 times since then...
Now, it switches from 2.4ghz/5 to 5ghz/36 and via verse instantly......Awesome! :s22:
Bro! Thank you so much for your valuable advice! You save my day! :)
Thanks again! :s22:
kelvinti
My neighbourhood shop got ready stock but selling at $358! :eek:
Chop cucumber head mei! :eek:
But again! To be fair! They needs to mark up from $299 to earn wah! :s8:
So, let's do the sum:
> $358 - $299 = $59 extra.
> Let's say you use the phone for 2 years (24 months).
> It's just a mere $2.45 extra per month or $0.08 extra per day over 24 months compared to Xiaomi official price of $299.
> So, no feel at all, right!
Not the bad actually since this is a good phone! So, just get it while stock lasts before you regret!
So, I think it's reasonably high price if you want to get one now! :s22:
PC-User
Well, 16:9 always look better than 4:3.
I have never used 4:3 even though it has full 16MP pixel. 4:3 looks funny unless you don't mind to crop it to 16:9 after every shots.
Actually it depends on the objects you're taking photo of. Sometimes wide frame very difficult to avoid the unwanted objects at both (left & right) sides. 4:3 may be too squarish but this old school format is most suitable under certain situations like photo of someone accepting prize/certificate etc. The best balance is 3:2 which is the same as standard 4R print.
Just Me
Someone mentioned that challenger has stocks. Might as well buy from there
